8*T30 30" dual 12" european
shawn_g
Re: 8*T30 30" dual 12" european
#46 Post by shawn_g »
Looks great. I like the design on the mouth braces!
Marflinger
#47 Post by Marflinger »
Sadly timing is not on my side, but the exploded workload should slowly ease from now on.
I got the cab finished yesterday, had to think about the connection at first, i think i'll go with that for all of the cabs.
Space sufficient, less cables inside, only one point with importance of airtight...and every connector is flush :)
All sealed
Before the mouthbrace
And done, glue is setting right now.
As the winter returned again, this will take more time as i would like it to; but nothing i can change.
Will do the flanges as soon as i can, and then place some woofers in there to check if the sealing has worked. But i am pretty sure it should be airtight everywhere.
DR250 (2 done, 2 to go)
8 T30 (in building phase)
driverack PA+
Wharfedale DP4065F
Prokustik FP14000
shawn_g
#48 Post by shawn_g »
Looks great! I'll be curious to hear your impression when you get a chance to test it.
Marflinger
#49 Post by Marflinger »
Well yeah, nothing on the time side is on my side...
I stole some of the unavailable time, got the flanges and filled the holes...but not yet further -.-
Flanges done, will def do them in one piece the next cabs. For aligning during build, to avoid the build inside chamber now...would be a win even with more wasted wood.
Corrected oopsie, glued replacement and trimmed flush
driverack PA+
Wharfedale DP4065F
Prokustik FP14000
#50 Post by Tom Smit »
"Corrected oopsie, glued replacement and trimmed flush"
Good recovery.
Marflinger
#51 Post by Marflinger »
Tom Smit wrote: Tue Mar 31, 2026 9:31 pm "Corrected oopsie, glued replacement and trimmed flush"
Good recovery.
Had the panel underneath when cutting some bracings with the circular saw...thought the cutline was clear, turned out it was not and the corner got lost^^
But as it was about fixing shorted panels elsewhere, i thought showing the recovery maybe helps someone.
Really not a problem to fix.
driverack PA+
Wharfedale DP4065F
Prokustik FP14000
