My Table Tuba LS build
Just put the side on my TTLS, here are some of the build pictures
- Attachments
Re: My Table Tuba LS build
they keep comming
This is how it is sitting at the moment, I don't have any clamps large enough for this thing, but I have plenty of heavy boxes, so I stacked about 200kg on top of it
- Bas Gooiker
Looking mighty proffesional for a second build!!! Im impressed.
What a difference the right tools make when doing a complicated build like this.
I have a quick question, I am planning to down fire this thing. Is there an optimum distance from the floor to set it at?
It looks to me that as the fastener pokes through the t-nut it will end up contacting the brace. That could end up distorting the panels, or busting a glue joint in that area.
Other than that, great build so far. Nice use of the router
- Scott Brochu
That's the same reason I off set mine so it don't end up on a brace. If so just cut the bolt or put a smaller one in that place.Radian wrote:Have you double-checked the clearance of those two t-nuts underneath the baffle brace?
Agreed, great build.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
I checked the length of the screws under full gasket compression, so no problems thereRadian wrote:Have you double-checked the clearance of those two t-nuts underneath the baffle brace?
I tried it out this morning, I am impressed!! much the same type of sound as my autotuba but just lower.
I tried watching a movie, but I don't have a high pass filter so I had to turn it down or the driver would bottom out :\. still though at 2v it's plenty loud for normal movie watching
Nice. Love the use of router for dadoing braces.
Nice job staining that plywood. Not fun getting an even color on ply.
