My Table Tuba LS build
AlessandroAU
#1 Post by AlessandroAU »
Just put the side on my TTLS, here are some of the build pictures :D
This thing is gonna be huge
panels ripped to size
the only other place I am allowed to make with the dust :roll:
the 'workshop' where I ripped up the panels
bought some new tools for this project, my first circular saw and router :) my previous build (autotuba) was done only using a $20 jigsaw and it was not much fun.
AlessandroAU
Re: My Table Tuba LS build
#2 Post by AlessandroAU »
some more pictures
full set of braces
full set of braces
cutting the braces did not take a long as expected. I just used cheap bandsaw and a steady hand, didn't even need sanding afterwards.
more dry fitting, I decided to continuous braces for the bottom most for ease and segmented braces for the mid and top I hope this is ok?
quite happy with how these turned out
first time using a router, things went better than expected
AlessandroAU
#3 Post by AlessandroAU »
and more
I used this for the braces
my build order and techniques might be slightly different than the plans
who needs clamps and jigs when you pre-measured and have lots of screws.
The first panel goes on
I ended up redrawing the mid braces in autocad, I modified them so the sides are perpendicular to one of the ends (they are not in the sketchup), this makes measuring and cutting them out easier.
AlessandroAU
#4 Post by AlessandroAU »
they keep comming
This is how I solved the problem
I thought about mounting the brace slightly offset but decided against it.
shit, my t-nuts interfere with the brace.
driver cut-out for the 8 inch dcs205-4
almost forgot to install panel 4
AlessandroAU
#5 Post by AlessandroAU »
more
I thought the braces looked quite cool, so I took a bunch of pictures.
braces are glued, this was SOOOO much easier with dadoing
AlessandroAU
#6 Post by AlessandroAU »
This is how it is sitting at the moment, I don't have any clamps large enough for this thing, but I have plenty of heavy boxes, so I stacked about 200kg on top of it :lol:
Bas Gooiker
#7 Post by Bas Gooiker »
Looking mighty proffesional for a second build!!! Im impressed.
What a difference the right tools make when doing a complicated build like this.
AlessandroAU
#8 Post by AlessandroAU »
I have a quick question, I am planning to down fire this thing. Is there an optimum distance from the floor to set it at?
#9 Post by Radian »
:shock: Have you double-checked the clearance of those two t-nuts underneath the baffle brace?
It looks to me that as the fastener pokes through the t-nut it will end up contacting the brace. That could end up distorting the panels, or busting a glue joint in that area. :fingers:
Other than that, great build so far. Nice use of the router :clap:
Scott Brochu
#10 Post by Scott Brochu »
Radian wrote::shock: Have you double-checked the clearance of those two t-nuts underneath the baffle brace?
That's the same reason I off set mine so it don't end up on a brace. If so just cut the bolt or put a smaller one in that place.
Agreed, great build. :clap:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
AlessandroAU
#11 Post by AlessandroAU »
I checked the length of the screws under full gasket compression, so no problems there :)
I tried it out this morning, I am impressed!! much the same type of sound as my autotuba but just lower.
I tried watching a movie, but I don't have a high pass filter so I had to turn it down or the driver would bottom out :\. still though at 2v it's plenty loud for normal movie watching :)
2Channon
#12 Post by 2Channon »
Nice. Love the use of router for dadoing braces. :clap:
AlessandroAU
#13 Post by AlessandroAU »
Sooooo I finally ended up finishing my TTLS :)
#14 Post by LelandCrooks »
Nice job staining that plywood. Not fun getting an even color on ply.
#15 Post by Tom Smit »
Say, wait! That there is a subwoofer??? It looks to good for that. :lol:
