WH10 CD vs Peizo
Keryn O'Shea
WH10 CD vs Peizo
G'day gents,
I'm about to head into WH builds, with the 10 first up.
Can anyone shed light on pros & cons of the CD HF option?
Would l be right to say the WH10 (MA+2510) fitted with a pole mount, could do double duty as a top for a pair of subs? If you're just looking for background music at a gathering, lower level PA.
Re: WH10 CD vs Peizo
You can use it in both applications with either configuration. The difference is width of the dispersion angle.
Keryn O'Shea
Excellent
Would the order for widest to narrowest WH HF dispersion be: Panel- Melded- CD?
Is the reason for omitting the WH10 CD horn second flare building ease, or close distance to the performer?
Could the WH8 be stretched to low level top duty also, crossing over at 110Hz?
Yes to all.
Keryn O'Shea
More great news, thank you very much mate!
Keryn O'Shea
I'm thinking of adding the second flare and diffuser rod to the the WH10 CD horn, as l have enough stock of GT1016s to complete pairs of the WH8 & 6, but not all three models of WH.
Reason being 1016s end up at around Au$8ea to us, & l have plenty of CDs here. I'd prefer not to use the Daichi 1016 version available to us here.
Would the loss of horizontal dispersion using CDs vs MA be large? Keeping in mind, you'll have WH6&8s to use for the close monitoring also..
You can do that. I didn't bother as the somewhat higher sensitivity and wider dispersion tends to be not an issue when used as a floor wedge.
Keryn O'Shea
Checking in before l marry the horn to the flare & continue on with the shell, are you seeing any problems?
Looks good, if there's enough clearance to fit the HF driver.
I applaud you taking on WH10s. I built three of them many years ago - not an easy build with all of the combination miters.Keryn O'Shea wrote: ↑Sat Feb 28, 2026 11:22 pm Checking in before l marry the horn to the flare & continue on with the shell, are you seeing any problems?
Looks good.
Keryn O'Shea
Ok great, yes there's plenty, using an ASD1001B equivalent. Thank youBill Fitzmaurice wrote: ↑Sun Mar 01, 2026 8:01 am Looks good, if there's enough clearance to fit the HF driver.
Bruce Weldy wrote: ↑Sun Mar 01, 2026 9:09 am I applaud you taking on WH10s. I built three of them many years ago - not an easy build with all of the combination miters.
Looks good.
Thanks Bruce, yes l read your post on cutting the miter angles with a table saw, that'll definitely help others.
I'm using a track saw which l think makes those cuts easier.
The lower diffuser bracket has been the most challenging peice of this build so far, the only dimension which hasn't changed is the 1.5" side where it meets the horn, its been stretched & has opposing angles & taken a couple of attempts to get right. In assembly l've added a degree or two so it's not resting flat on the cabs horn mouth. I want the diffuser brackets to sit square so there's zero tension when screwed down at fitting.
A second laminated peice added & I'll use the mitre saw to correct the angle instead of removing material on the single peice & weakening the bracket. I may build the next CD horn in the mouth of the cab if l can find a way of holding the mouth reflectors in place while the adhesive sets, or just add a laminated peice from the start.
Keryn O'Shea
Had time & good weather to paint yesterday, so l did in the usual manner.
However l noticed this morning the paint had cracked in the joint line.
I'll cook the paint today, leave it for a few days & touch up the cracks, just wondering why?
It was a freshly opened gallon, nice dry weather at 25 degrees Celsius & l slapped it on in the usual way l always do & an hour between coats (x3)
I have also noticed how deep the horn is in the WH10, it's longer than the Jacks and OTs, & takes up a large volume of the cab.. should be potent!
Keryn O'Shea
One down, 5 to go..
With a couple of tweaks of just the mixers 3 band parametric, it's sounding sweet Sensitivity is very high, just breathe on the volume & we're awake!
Has anyone had experience with the WHs in wet weather? It would have to be heavy rain to make it into the horn when they're faced into the stage, maybe a strip of duct tape across the top would stop water running down into the woofer..?
Looking the goods on a pole too
I never did finish my WH project. Sadly, it got tossed when I changed life direction.
That came out amazing, Keryn.
Well done!
Well done!
