TAT Build
shane2943
TAT Build
#1 Post by shane2943 »
Good morrow everyone. Been working a few days on the TAT that will go into my double-cab Toyota Tundra. Will be 8" loaded and 14" wide OD.
On to the PITCHERS!
Look at all that beautiful squeeze out
Re: TAT Build
#2 Post by Tom Smit »
Looking good, so far. :clap:
shane2943
Re: TAT Build
#3 Post by shane2943 »
Thank you Tom!
MOAR PITCHERS
Currently letting panel 10 set up. Will hopefully get panel 11 in place today.
Semi-pro tip: using an infrared heater on medium low really helps the PL set up faster in cold weather. That's why you see the heater in a lot of the pics.
Re: TAT Build
#4 Post by Bill Fitzmaurice »
Spritz it too, cold air is dry air.
shane2943
Re: TAT Build
#5 Post by shane2943 »
Bill Fitzmaurice wrote: Fri Dec 12, 2025 2:46 pm Spritz it too, cold air is dry air.
Ah, good tip. Thanks!
shane2943
Re: TAT Build
#6 Post by shane2943 »
Panel 11 is now in place. Once it's set, I'll get the brace cut out. The brace is going to double as a brace and handle as I want the sub to be easily removable from the truck cab in case I need the space in the back seat.
Also, can NEVER have too many clamps!
Re: TAT Build
#7 Post by AntonZ »
shane2943 wrote: Fri Dec 12, 2025 5:51 pmAlso, can NEVER have too many clamps!
Amen to that.
You are making good progress Shane. Thanks for sharing.
