cutting pvc
homemade hotrod
cutting pvc
came up with a simple yet effective way of halving pvc pipe to make reflectors for the dr280s i'm currently building
- Attachments
building:2 dr280 3012ho melded array
built:2 t-60 27" lab15
Re: cutting pvc
Re: cutting pvc
Ah you figured out the secret recipe of putting a plug in the pipe. The only kicker to that is the ID of differing brands of pipe varies more than you might think.
I hate cleaning up after cutting these things. Damn electrically charged shavings.
homemade hotrod
Re: cutting pvc
They are messy alright. As for the differing i.d., i cut a small section of the actual pipe i'm using to trace a circle onto mdf and sand to fitLelandCrooks wrote:Ah you figured out the secret recipe of putting a plug in the pipe. The only kicker to that is the ID of differing brands of pipe varies more than you might think.
Re: cutting pvc
I'm brainstorming for the non-table saw user: Maybe you could make a second jig to go on the other side of the pipe, clamp that together, then use your jig/circular saw to slice it down the middle. Only issue I see is you're cutting through the jigs.
David Raehn
Re: cutting pvc
Without a table saw, you can do just like Hotrod did, but add another bit to the top and bottom pieces to make it work like a circular saw sled.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
