cutting pvc
homemade hotrod
cutting pvc
#1 Post by homemade hotrod »
came up with a simple yet effective way of halving pvc pipe to make reflectors for the dr280s i'm currently building
cut 2 disks from mdf to fit i.d. tightly
clamp to jig
clamp to jig
cut one side flip jig cut second side
pipe closes down on disks not blade
pull apart and repeat safe and easy
building:2 dr280 3012ho melded array
built:2 t-60 27" lab15
Re: cutting pvc
#2 Post by Bruce Weldy »
:clap: :clap:
Re: cutting pvc
#3 Post by Tom Smit »
Yup. :clap:
Re: cutting pvc
#4 Post by LelandCrooks »
Ah you figured out the secret recipe of putting a plug in the pipe. The only kicker to that is the ID of differing brands of pipe varies more than you might think.
I hate cleaning up after cutting these things. Damn electrically charged shavings.
homemade hotrod
Re: cutting pvc
#5 Post by homemade hotrod »
LelandCrooks wrote:Ah you figured out the secret recipe of putting a plug in the pipe. The only kicker to that is the ID of differing brands of pipe varies more than you might think.
They are messy alright. As for the differing i.d., i cut a small section of the actual pipe i'm using to trace a circle onto mdf and sand to fit :D
jimbo7
Re: cutting pvc
#6 Post by jimbo7 »
I'm brainstorming for the non-table saw user: Maybe you could make a second jig to go on the other side of the pipe, clamp that together, then use your jig/circular saw to slice it down the middle. Only issue I see is you're cutting through the jigs.
David Raehn
Re: cutting pvc
#7 Post by David Raehn »
Without a table saw, you can do just like Hotrod did, but add another bit to the top and bottom pieces to make it work like a circular saw sled.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
:noob:
