Bill Fitzmaurice wrote:OSB?
 Not sure if it is my eyes, but I can't see much evidence of PL squeeze out... or any glue for that matter. Is this a dry fit / practice build?miked wrote:PL probably filled all the gaps in the OSB
I think that is correct... as far as I know the T30 is the only one like this. Not sure why, or what you would call the restriction in speaker building parlance?sine143 wrote:Notice how as it goes around the bend the horn gets smaller
He built it correctly. The first part is supposed to be wider before the fold than after..sine143 wrote:The forst section in the horn also does not look quit right to me. Notice how as it goes around the bend the horn gets smaller. Id double check the measurments
88h88 wrote:If he hadn't said it was a test build I'd almost say this was the perfect troll build. Differing widths of cheap asian ply, OSB, WOOD GLUE...
 Troll building.  Could this be the beginning of a new internet sport?
 Troll building.  Could this be the beginning of a new internet sport?YES! Kitchen-builds, FTW!!sine143 wrote:I remember it being a different flare, but not that drastic reduction in size. You guys are making me take the way back machine to my first build lol
 Done about a hundred of those myself...don't miss those days one bit.  Ever try to get black paint overspray off a white stove?  Not fun.
  Done about a hundred of those myself...don't miss those days one bit.  Ever try to get black paint overspray off a white stove?  Not fun.88h88 wrote:If he hadn't said it was a test build I'd almost say this was the perfect troll build. Differing widths of cheap asian ply, OSB, WOOD GLUE...
 hahaha... Its a starting trend.. Did a certain someone, building t60's, start this?!?!
  hahaha... Its a starting trend.. Did a certain someone, building t60's, start this?!?!A little wood glue, mostly dry fitIan Westwood wrote:Not sure if it is my eyes, but I can't see much evidence of PL squeeze out... or any glue for that matter. Is this a dry fit / practice build?miked wrote:PL probably filled all the gaps in the OSB
