Tuba 30 Build (I upgraded Bill plans) Thank me later Bill
darklango
#1 Post by darklango »
This build consist of wood glue, Asian Ply1/2, Asian Ply 3/4, and OSB 1/2. Cant wait to hear this baby :hyper: :hyper: :hyper: :hyper: :hyper: :hyper: :hyper:
Re: Tuba 30 Build (I upgraded Bill plans) Thank me later Bil
#2 Post by Bill Fitzmaurice »
OSB? :wall:
darklango
#3 Post by darklango »
Bill Fitzmaurice wrote:OSB? :wall:
:D :D
I wanted to practice b4 we did the real box. But I'm curious on how its sounds now
miked
#4 Post by miked »
I hear you on practicing before using the expensive wood. But don't expect this box to last long. OSB will delaminate quickly with the pressure the box will be under. PL probably filled all the gaps in the OSB, but the box won't last long if you move it much.
Hopefully you're building the real thing out of 1/2" Baltic Birch.
Ian Westwood
#5 Post by Ian Westwood »
miked wrote:PL probably filled all the gaps in the OSB
Not sure if it is my eyes, but I can't see much evidence of PL squeeze out... or any glue for that matter. Is this a dry fit / practice build?
Authorized BFM Builder
sine143
#6 Post by sine143 »
The forst section in the horn also does not look quit right to me. Notice how as it goes around the bend the horn gets smaller. Id double check the measurments
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
Ian Westwood
#7 Post by Ian Westwood »
sine143 wrote:Notice how as it goes around the bend the horn gets smaller
I think that is correct... as far as I know the T30 is the only one like this. Not sure why, or what you would call the restriction in speaker building parlance?
miked
#8 Post by miked »
"Horn path clogification?" :lol:
sine143
#9 Post by sine143 »
I remember it being a different flare, but not that drastic reduction in size. You guys are making me take the way back machine to my first build lol
1x bastard XF208
Michael Ewald Hansen
#10 Post by Michael Ewald Hansen »
sine143 wrote:The forst section in the horn also does not look quit right to me. Notice how as it goes around the bend the horn gets smaller. Id double check the measurments
He built it correctly. The first part is supposed to be wider before the fold than after..
This is from the sketchup:
Last edited by Michael Ewald Hansen on Thu Oct 17, 2013 4:20 pm, edited 1 time in total.
Authorized Builder - Denmark
88h88
#11 Post by 88h88 »
If he hadn't said it was a test build I'd almost say this was the perfect troll build. Differing widths of cheap asian ply, OSB, WOOD GLUE... :lol:
Ian Westwood
#12 Post by Ian Westwood »
88h88 wrote:If he hadn't said it was a test build I'd almost say this was the perfect troll build. Differing widths of cheap asian ply, OSB, WOOD GLUE... :lol:
:loler: Troll building. Could this be the beginning of a new internet sport?
miked
#13 Post by miked »
sine143 wrote:I remember it being a different flare, but not that drastic reduction in size. You guys are making me take the way back machine to my first build lol
YES! Kitchen-builds, FTW!! :clap: Done about a hundred of those myself...don't miss those days one bit. Ever try to get black paint overspray off a white stove? Not fun.
#14 Post by Michael Ewald Hansen »
:loler: hahaha... Its a starting trend.. Did a certain someone, building t60's, start this?!?!
darklango
#15 Post by darklango »
A little wood glue, mostly dry fit
