Zefren's Reservation Tuba 60
zefrenm
day 5 part VI
#31 Post by zefrenm »
day 5 part VI
Transferring the number of screws per panel from the driver side panel to the cap panel.
Spacing the screw hole markers (aka HD thumb tacks)
Aligning the cap with the tacks before using a rubber mallet to drive the  tacks in.
The inside of cap panel marked.
Drilling out to and counter sinking from the outside.
zefrenm
day 5 part VII
#32 Post by zefrenm »
day 5 part VII
Sanding the panels more or less flat so the PL squeezes out uniformly.
Double checking.
Double checking.
The cap side access to the Speakon connection.
Bracing up panel 12 before cutting. Normally id leave this to cure another day but like I said were in a crunch.
Marking and drilling the holes for the braces.
zefrenm
day 5 VIII
#33 Post by zefrenm »
day 5 VIII
Grandpas ratcheting hand brace fitted with a screws bit. Its takes a while to get used to the added torque it gives you so but extra long screws for when you strip the wood.
Nice even squeeze out of PL.
Panel 13 install and staining.
Panel 12 and Speakon access chamber staining.
We use ¾ a tube of PL when capping  “just because .”
zefrenm
Day 5 part IX
#34 Post by zefrenm »
Day 5 part IX
Almost there, we spray the joints with water to help the PL cure, tomorrow the tuba will sun tan all day.
Using a screw to true panel 12 to the cap panel.
Using light and looking at all the joints for PL squeezage. Lol is it doesn’t, we filling with more PL.
5:30 am Woot Woot done, well almost. ;D
bassmonster
Re: Zefren's Reservation Tuba
#35 Post by bassmonster »
This is one of the quickest T60 builds I've ever seen, nice work. :clap: Can't wait to see a video when it's done.... :fingers:
Re: Zefren's Reservation Tuba 60
#36 Post by Radian »
:clap:
Lot's of good tricks here. The thumb-tack idea is brilliant.
subharmonic
#37 Post by subharmonic »
Radian wrote::clap:
+1
I like the 3/4 tube of PL comment. The more the merrier.
I need more bass
CW Mcall
zefrenm
Day 6
#38 Post by zefrenm »
:fruit: No work, We felt like we just went through a graveyard to morning shift change and i never made it out the house. Tomorrow (Sunday) try to finish the corners, l bars and handles. :|
zefrenm
Day 7
#39 Post by zefrenm »
Day seven. Church day today but I will finished the driver access panel and install the driver.
I took an silver smithing class in High school, I guess if your handy with welding then you can do this to, but is you can solder electronics you can solder 1x60 12 gauge metal bate from home depot.
3/8 of the metal contacts the drive access panel and is sealed with pl so accuracy is the key.
Dry fitting the pieces before soldering
Wipe with flux, and heat until the flux boils and take the flame away and see if the solder runs up the joint, If it doesn’t then keep heating the bar.
Sanding the back side helps the PL bond a little more to the driver panel than a smooth surface.
zefrenm
Day 7 Continued
#40 Post by zefrenm »
Day 7 Continued
Test fitting the drive access panel to the Tuba.
More smiling handle holes.
The Driver and Tuba meet for the first time and it’s love at first sight. Lol
Soldering the female connectors to the wire and tin the driver leads to save the wire.
Sealing the the driver chamber with Blue RTV silicone gasket maker, we use small strips of wax paper between the driver panel surface the driver panel access cover to make future access easier.
zefrenm
Day 7 part III
#41 Post by zefrenm »
Day 7 part III
Prepping the previous tubas for their last sing before we ship out their Peavey lo Riders  for Lab 15s.
Using the tee configuration to test the tuba. One word WOW.  You tube video to follow shortly.
88h88
#42 Post by 88h88 »
That last picture... :shock:
zefrenm
Zefren's Reservation Tuba 60 Test
#43 Post by zefrenm »
Dan30
Re: Zefren's Reservation Tuba 60 Test
#44 Post by Dan30 »
zefrenm wrote:
Awesome! How hard were you pushing it?
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
zefrenm
#45 Post by zefrenm »
Awesome! How hard were you pushing it?[/quote]
we dont have a voltmeter yet so the 11 o clock position on the TXI 1500 crown amp.
