I would like to safely use my T36 to reproduce 20hz (and below) content. Generally I high pass at 30hz, but I have an occasion coming up that requires extra bass depth. Plus I'm just curious... We're gonna run a bunch of test tones and sweeps before the show, and I want the T36 to shine.
I'm planning on V-stacking (with plate) four T36. (Magnum and Definimax 15 loaded) According to the SPL charts 20hz at 100+ SPL shouldn't be a problem. I believe those numbers are "pre" V-plate technology as well...?
Is there a lower limit to what the driver can physically reproduce inside the horn? Can I still feed the driver 600 watts or should I dial that back a bit? Anything I need to do differently as far as limiting/compressing/crossing? I generally cross at 80 or 90 with the LR24 curve. Do I need to lower my crossover point to compensate for the additional stress of a lower HPF?
thanks.
sub bass safety.
- Zack Brock
Is this the same for a 24" dual BP102 T24?Bill Fitzmaurice wrote:T36 unloads below 22 Hz. More than 200 watts input below 22Hz runs the danger of exceeding xlim, damaging the driver.
Zack Brock
- Zack Brock
Re:
Sorry to dig up an old thread but I am curious - does a single BP102/S2010 loaded 16' wide Tuba 24 unload at 38Hz? In other words, is it 38Hz because it is a dual loaded cab (essentially two in one?).Bill Fitzmaurice wrote:It unloads below 38 Hz.bassbrock wrote:Is this the same for a 24" dual BP102 T24?Bill Fitzmaurice wrote:T36 unloads below 22 Hz. More than 200 watts input below 22Hz runs the danger of exceeding xlim, damaging the driver.
Zack Brock
Re: sub bass safety.
The unload frequency is relatively unaffected by the driver used.
