sub bass safety.
Christian
sub bass safety.
#1 Post by Christian »
I would like to safely use my T36 to reproduce 20hz (and below) content. Generally I high pass at 30hz, but I have an occasion coming up that requires extra bass depth. Plus I'm just curious... We're gonna run a bunch of test tones and sweeps before the show, and I want the T36 to shine.
I'm planning on V-stacking (with plate) four T36. (Magnum and Definimax 15 loaded) According to the SPL charts 20hz at 100+ SPL shouldn't be a problem. I believe those numbers are "pre" V-plate technology as well...?
Is there a lower limit to what the driver can physically reproduce inside the horn? Can I still feed the driver 600 watts or should I dial that back a bit? Anything I need to do differently as far as limiting/compressing/crossing? I generally cross at 80 or 90 with the LR24 curve. Do I need to lower my crossover point to compensate for the additional stress of a lower HPF?
thanks.
#2 Post by Bill Fitzmaurice »
T36 unloads below 22 Hz. More than 200 watts input below 22Hz runs the danger of exceeding xlim, damaging the driver.
Christian
#3 Post by Christian »
Since we're gonna run a 4-pack, 200 watts is plenty for the testing portion of the evening.
Does "unloading" mean that the horn component of the design no longer functions below 22hz?
#4 Post by Bill Fitzmaurice »
Christian wrote:Since we're gonna run a 4-pack, 200 watts is plenty for the testing portion of the evening.
It is below both the horn fc and the rear chamber fb, so the roll off is at a 24dB/octave rate.
Zack Brock
#5 Post by Zack Brock »
Bill Fitzmaurice wrote:T36 unloads below 22 Hz. More than 200 watts input below 22Hz runs the danger of exceeding xlim, damaging the driver.
Is this the same for a 24" dual BP102 T24?
Zack Brock
#6 Post by Bill Fitzmaurice »
It unloads below 38 Hz.
Zack Brock
Re:
#7 Post by Zack Brock »
Sorry to dig up an old thread but I am curious - does a single BP102/S2010 loaded 16' wide Tuba 24 unload at 38Hz? In other words, is it 38Hz because it is a dual loaded cab (essentially two in one?).
Zack Brock
Re: sub bass safety.
#8 Post by Bill Fitzmaurice »
The unload frequency is relatively unaffected by the driver used.
