Melded Array Difuser Dowel - which glue?
As the final part of melded array construction I need to attach the dowel to the front of the piezos. What is the best glue for this?  Hot melt?  PL? Something else?
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
						1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
- SoundInMotionDJ
Re: Melded Array Difuser Dowel - which glue?
I retrofitted the difuser using PVC.  I attached with hot melt glue.  3 years later and I can still pick up a DR200 only holding onto the difuser.
									10 T39S + 10 DR200 + 1 T48
				djtrumptight
I used hot melt,i also drilled a hole through the top and bottom of the cab,down the center of the dowel.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
I used a plastic tube of the same width as the dowel and glued it to the array with the same glue used to stick the tweeters together.
1/2 cpvc pipe.  Abs, airplane, or combo plastic pipe glue.
