Melded Array Difuser Dowel - which glue?
billkatz
#1 Post by billkatz »
As the final part of melded array construction I need to attach the dowel to the front of the piezos. What is the best glue for this? Hot melt? PL? Something else?
1 Omni-15 Tall Boy
2 DR250s
2 Titan 39s
SoundInMotionDJ
Re: Melded Array Difuser Dowel - which glue?
#2 Post by SoundInMotionDJ »
I retrofitted the difuser using PVC. I attached with hot melt glue. 3 years later and I can still pick up a DR200 only holding onto the difuser.
10 T39S + 10 DR200 + 1 T48
djtrumptight
#3 Post by djtrumptight »
I used hot melt,i also drilled a hole through the top and bottom of the cab,down the center of the dowel.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
whines
#4 Post by whines »
I used a plastic tube of the same width as the dowel and glued it to the array with the same glue used to stick the tweeters together.
#5 Post by LelandCrooks »
1/2 cpvc pipe. Abs, airplane, or combo plastic pipe glue.
