Finishing cabs
Mnsouthpaw
Finishing cabs
Greetings,
About to finish my first set of 24's and have a question about filler products. Duratex recommends drywall spackling to ensure good adhesion and not to use Bondo. The build plans suggest going with Bondo or PL Premium. While I used PL for the build it seems awkward as a filler. Any adhesion problems with Bondo....any other suggestions?
Thanks,
Marko
Thanks,
Marko
Re: Finishing cabs
The main reason bondo is recommended is that it doesn't shrink. My experience with using PL to seal holes is that it bubbles some and may require some additional filling for a "perfect" result if you're not doing a textured finish.
So if it's not a large hole, one application of bondo does the job. Drywall spackle and many other fillers shrink some, and may mean another application to get it flat.
Most people do a primer/first coat in flat black on the cabs before Duratex, and by and large that leads to good results, and using less Duratex...
Mnsouthpaw
Re: Finishing cabs
Grant,
Thanks for the feedback, most appreciated.
OI...OI...OI...Aussie, Aussie,Aussie.....you folks are fun!!
Kindest,
Marko
Kindest,
Marko
Re: Finishing cabs
Pictures, please
Mnsouthpaw
Re: Finishing cabs
Hi Ryan,
Very sorry for the delay with pics, I've been have a heck of at time with my computer. About had it with this platform...might take a bite of the big Apple soon.
I'll try taking a different approach and see if I can't get something posted soon. My build is per plan, nothing out of the ordinary.
Marko
Marko
MissileCrisis
Re: Finishing cabs
This is the BFM forum, we love staring at BFM cabs no matter how plain jane!! I hope you like your subs!Mnsouthpaw wrote:Hi Ryan,
Marko
*also waiting for pics.
2 x TLAH
1 Titan 39 (lab 12, 15 inch)
1 Tuba 60 (lab 12, 20 inch)
SLA Center
2 x Mini MLTP subwoofers
1 x 212 TH (custom)
2 x Mini-Karlsonators
Owned, but not built
2 x Jack 12 (2512, melded)
2 x TLAH
SLA Center
1 x 212 TH (custom)
Re: Finishing cabs
On latest builds, been using the new filler putty from Elmer's. Pro grade. Hardens in about 15 minutes. Sands real well. Very well. When done, the sanded portion looks just like wood and is hard as the wood.
First two cabinets have been sprayed professionally with Vortex. Hard shell but not slippery like Duratex, and not rock feeling like lineX. Its is hard though. I used Duratex in the handles area, and then they sprayed over it, just in case they couldn't reach in the insides of the handles. Have used Duratex many times with great results, just wanted something harder on these subs.
Re: Finishing cabs
Can you post a link, please?sddj wrote:On latest builds, been using the new filler putty from Elmer's. Pro grade. Hardens in about 15 minutes. Sands real well. Very well. When done, the sanded portion looks just like wood and is hard as the wood.
- racertomtom
Re: Finishing cabs
4 - WH8
2 - T39 24" Lab12
2 - OT12 3012HO/NSD2005
2 - T39 24" Lab12
Michael Murphy
Re: Finishing cabs
That was cool! lol
Re: Finishing cabs
Here's a few pics of different angles with Vortex. Don't mind the "pinkish" color, that was from some uplighting we had on the walls in the area... FYI, if any of you are Packer fans, this wedding was actually at Lambeau Field. Two of 12 are built and finished, 2 more will be sprayed this week, then on to #5-#12.
- Attachments
- T30-17d(small).jpg (18.6 KiB) Viewed 3438 times
- T30-17a (small).jpg (20.37 KiB) Viewed 3438 times
Re: Finishing cabs
uh oh, now you've done it.
where your braces at
Re: Finishing cabs
Re: Finishing cabs
Because that's life. Not everything can be "ideal", as corner placement, boundary placement, etc. We have to roll the way we can.
Re: Finishing cabs
I'm not asking about boundary loading, I am wondering about splitting your subs. Are you in a very small room? You do know you gain 6dB just by stacking 2 sub cabs together, but you create null zones and power alleys by splitting. I fully understand not always being able to boundary load, but why lose coupling gains? The exception would be in a really small room, as you would split the subs to try to even out response. I may be reading too much into the pictures you provided, but it appears like you have your subs split under your tops. If you don't, my bad.sddj wrote:Because that's life. Not everything can be "ideal", as corner placement, boundary placement, etc. We have to roll the way we can.
