OmniTop 12 and Tuba 30
digi128pci
#1 Post by digi128pci »
Hi,
I have just started the build of my first OT12.
I'm no carpenter but i decided to give it a try.
The wood i used is poplar, I hope that it is good enough for the job. Anyway it's very light.
I also bought TopHats so i can mount theme on a speaker stand. But where do i need to make a hole for the hat?
http://www.thomann.de/be/km_19656_flanschbuchse.htm
They are tall, so i suspect that they would go trough the Throat reflector.
The Throat reflectors aren't installed yet, i think they will be a pain in the ass if i need to cutout the tophat.
Any Idea's or comments? Is it better to shorten the tophat?
Edit:
How do i mount the driver on the spacer? I have T-nuts, so just drill a hole and put T-Nut in and then use short bolts?
Here are some Pic's:
Re: OmniTop 12 and Tuba 30
The top hat mount is in the plans. The plans also recommend using screws for the woofer; if you were to use Tnuts they, and the spacer, would have to have been installed before the cab was assembled.
digi128pci
#3 Post by digi128pci »
Bill Fitzmaurice wrote:The top hat mount is in the plans. The plans also recommend using screws for the woofer; if you were to use Tnuts they, and the spacer, would have to have been installed before the cab was assembled.
Thx Bill, So If i understand the plans correct, first install the Throat reflectors, and at the end of the build make a hole where the top hat has to go?
Greets,
Digi
#4 Post by Bill Fitzmaurice »
Greets,
Digi
That's the easiest method to get the hole lined up properly. With a holesaw use a longer pilot bit than standard.
bzb
#5 Post by bzb »
I positioned mine so that the tube part is less than 1/4" in front of the baffle. I used the old baffles, however, so they're in front of the solid portion of the baffle.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
digi128pci
#6 Post by digi128pci »
Hi, I just realized i used B-grade poplar with only 3 layers (I tought you counted the thinner layers to :bash: ), should i continue the build or search for better wood :noob: ?
digi128pci
#7 Post by digi128pci »
Allright now i'm confused, i called my lumberyard today and they told me its 7 layers. Maybe i should post a picture of the wood ...
Edit: They also told me that the wood is from rioja-area in Spain. The class they specify is BB.
#8 Post by Bruce Weldy »
digi128pci wrote:Allright now i'm confused, i called my lumberyard today and they told me its 7 layers. Maybe i should post a picture of the wood ...
that is not Baltic Birch. It should have even plys, not a thin veneer on the outside. the lumberyard is :bull: ing you.
#9 Post by Bill Fitzmaurice »
I see seven plies.
#10 Post by Tom Smit »
That's what I counted, too. What got me was that, on the top, that layer looked thinner, so I wasn't sure if it was a ply or a veneer.
jswingchun
#11 Post by jswingchun »
Please put your location in your profile, maybe someone is near you and can suggest a plywood source.
Second time I have posted this in the last five minutes for two different members...
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Greg Plouvier
#12 Post by Greg Plouvier »
That ply looks fine to me. On another note, after clicking on the ply pic, seems my computer was attacked by something....anybody else get that?
Greg Plouvier
Drey Chennells
#13 Post by Drey Chennells »
Greg Plouvier wrote:That ply looks fine to me. On another note, after clicking on the ply pic, seems my computer was attacked by something....anybody else get that?
hmm not yet :fingers:
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
digi128pci
#14 Post by digi128pci »
No the wood is Popular. Allright then there are 7 layers. I think 3 ticker layers and 4 smaller layers.
The question is should i use this wood (Light and relative cheap about 10 euro/m2) or should i get other wood with even tick layers and call this a practice build :?:
What attacked :confused: :chainsaw: . If so plz tell me and i will use other site to upload photo's.
Greg Plouvier
#15 Post by Greg Plouvier »
I tried the picture again and it seems ok - AVG weirdness maybe?? Anyway that plywood looks fine. BB is the grade - not an abbreviation for baltic birch. A lot of big companies are using poplar now because it's light.(Dynacord for one)
Greg Plouvier
