I have just started the build of my first OT12.
I'm no carpenter but i decided to give it a try.
The wood i used is poplar, I hope that it is good enough for the job. Anyway it's very light.
I also bought TopHats so i can mount theme on a speaker stand. But where do i need to make a hole for the hat?
http://www.thomann.de/be/km_19656_flanschbuchse.htm
They are tall, so i suspect that they would go trough the Throat reflector.
The Throat reflectors aren't installed yet, i think they will be a pain in the ass if i need to cutout the tophat.
Any Idea's or comments? Is it better to shorten the tophat?
Edit:
How do i mount the driver on the spacer? I have T-nuts, so just drill a hole and put T-Nut in and then use short bolts?
Here are some Pic's:
 ), should i continue the build or search for better wood
 ), should i continue the build or search for better wood   ?
 ing you.
 ing you.
   . If so plz tell me and i will use other site to upload photo's.
