Power conditioners
Rockboy
Power conditioners
#1 Post by Rockboy »
Do you need a power conditioner and if so, a couple of recommendations would be nice.
RR
Re: Power conditioners
#2 Post by Radian »
Not really.
If the power of the venue is junk enough to hear it through your rig, balanced isolation transformers can sometimes fix the issue.
#3 Post by LelandCrooks »
Big money for the real deal.
#4 Post by Bill Fitzmaurice »
The only 'conditioner' that really works is a 110-0-110 to 55-0-55 volt transformer, providing balanced A/C, connected to a 220 outlet. Very large, heavy and expensive, so it's very much a permanent install item for studios.
Everything else is basically snake-oil.
Dave Non-Zero
#5 Post by Dave Non-Zero »
I've always wondered if one or more of those huge capacitors that you get for car audio would help smooth out ragged mains power?
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
#6 Post by Bill Fitzmaurice »
Dave Non-Zero wrote:I've always wondered if one or more of those huge capacitors that you get for car audio would help smooth out ragged mains power?
Only if you have DC mains in your neck of the woods.
Dave Non-Zero
#7 Post by Dave Non-Zero »
Haha yeah ok then maybe not. Good point. :) Think Tesla showed Edison that wasn't a good idea. :)
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
NCcrashman
#8 Post by NCcrashman »
Tesla showed Edison everything...lol..hehe
-crash
"If it's too loud, your too old! What's that? I didn't hear you"
Friends don't let friends use crappy speakers!
#9 Post by Bill Fitzmaurice »
NCcrashman wrote:Tesla showed Edison everything...lol..hehe
-crash
But Edison showed Tesla the door. :loler:
Rockboy
#10 Post by Rockboy »
So save the extra $$$
and don't buy something like
gdougherty
#11 Post by gdougherty »
The nicer Furmans are good to have if for nothing other than the built-in voltmeter. I have one in my amp rack so I can see what I'm getting from the wall or generators.
Rockboy wrote:So save the extra $$$
Don't spend more than $50 is the rule.
A voltmeter is a feel-good feature IMO. If the voltage is off what are you going to do about it? Walk out on the gig?
guitarkeys.com
#13 Post by guitarkeys.com »
Well then you break out you Analysis Plus Oval series IEC power cable... it will solve all your problems...
http://www.nxtbook.com/nxtbooks/newbay/ ... startid=62
Jamie
Jamie
Fayetteville, AR
gdougherty
#14 Post by gdougherty »
Not plug anything into the Generator that's supplying >130V and tell the event organizers that it's unnacceptable because I've killed power conditioners in those scenarios or adjust the generator's output voltage if that's a possibility. A multi-meter would work as well, but then I have to carry one separately. If it's built into at least one of my conditioners I can plug that in and check. It's the first thing I do when dealing with an unknown generator.
Monomer
#15 Post by Monomer »
I've experienced voltage drops down to 92vac
Mind you, this was in the Leland building in Detroit. I should have walked off the gig as it was a non-paying show and the low voltage killed my BBE DS48 (promptly replaced by BBE a week later)
The furman did nothing to save anything plugged in. It is nothing more then a surge strip thats rackmountable.
-More to come!
