Power conditioners
Power conditioners
Do you need a power conditioner and if so, a couple of recommendations would be nice.
RR
RR
Re: Power conditioners
Not really.
If the power of the venue is junk enough to hear it through your rig, balanced isolation transformers can sometimes fix the issue.
Big money for the real deal.
The only 'conditioner' that really works is a 110-0-110 to 55-0-55 volt transformer, providing balanced A/C, connected to a 220 outlet. Very large, heavy and expensive, so it's very much a permanent install item for studios.
Everything else is basically snake-oil.
- Dave Non-Zero
I've always wondered if one or more of those huge capacitors that you get for car audio would help smooth out ragged mains power?
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Only if you have DC mains in your neck of the woods.Dave Non-Zero wrote:I've always wondered if one or more of those huge capacitors that you get for car audio would help smooth out ragged mains power?
- Dave Non-Zero
Haha yeah ok then maybe not. Good point.
Think Tesla showed Edison that wasn't a good idea.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
NCcrashman
Tesla showed Edison everything...lol..hehe
-crash
-crash
"If it's too loud, your too old! What's that? I didn't hear you"
Friends don't let friends use crappy speakers!
But Edison showed Tesla the door.NCcrashman wrote:Tesla showed Edison everything...lol..hehe
-crash
So save the extra $$$
and don't buy something like
- Attachments
- PL-8C-front_page.jpg (5.23 KiB) Viewed 2308 times
gdougherty
The nicer Furmans are good to have if for nothing other than the built-in voltmeter. I have one in my amp rack so I can see what I'm getting from the wall or generators.
Don't spend more than $50 is the rule.Rockboy wrote:So save the extra $$$
A voltmeter is a feel-good feature IMO. If the voltage is off what are you going to do about it? Walk out on the gig?
guitarkeys.com
Well then you break out you Analysis Plus Oval series IEC power cable... it will solve all your problems...
http://www.nxtbook.com/nxtbooks/newbay/ ... startid=62
Jamie
Jamie
Jamie
Fayetteville, AR
In Pursuit Of Audio Perfection
"A Bad Mix is Bad at Any Volume"
Fayetteville, AR
gdougherty
Not plug anything into the Generator that's supplying >130V and tell the event organizers that it's unnacceptable because I've killed power conditioners in those scenarios or adjust the generator's output voltage if that's a possibility. A multi-meter would work as well, but then I have to carry one separately. If it's built into at least one of my conditioners I can plug that in and check. It's the first thing I do when dealing with an unknown generator.Bill Fitzmaurice wrote:Don't spend more than $50 is the rule.Rockboy wrote:So save the extra $$$
I've experienced voltage drops down to 92vacBill Fitzmaurice wrote:Don't spend more than $50 is the rule.Rockboy wrote:So save the extra $$$
Mind you, this was in the Leland building in Detroit. I should have walked off the gig as it was a non-paying show and the low voltage killed my BBE DS48 (promptly replaced by BBE a week later)
The furman did nothing to save anything plugged in. It is nothing more then a surge strip thats rackmountable.
-More to come!
-More to come!
