Duratex or equivalent in NZ/OZ
Calling all builders from down under!
I'm wondering if there's Duratex or a similar product available this side of the world.
Or any suggestions for a finish on a T39. I'm a bit worried at the quantity and cost of carpet & glue required to cover such a beast!
Thanks,
Alex
Thanks,
Alex
- Harley
Re: Duratex or equivalent in NZ/OZ
There's not.lalexb wrote:I'm wondering if there's Duratex or a similar product available this side of the world.
You could try concrete floor paint. No idea how it compares to Duratex/Warnex for durability but it is relatively cheap and can be given the same textured look when rolled on.
My standard for PA cabinet coatings is lower than Duratex - which is very nice. I want something tough, cheap, easily applied, and easily touched up infrequently.
My new favorite "in-house" cab coating is water-based, hardens nicely, and contains texturing which looks pretty good when applied with a roller.
$40 USD per gallon, stocked at Walmart, available globally http://www.plastikote.com/plastikote/splash/index.jsp
It is much harder & more durable than Tolex, and compares favorably to Line-X, though it is not as durable or pretty.
I've rolled it on at 40 DegreesF and it cured overnight in my cold shop. (Bring it in the house to dry faster - it doesn't stink!)
Don't buy it in a spray can - it clogs the tip too easily.
- Attachments
- promo-truck-bed-liner3.jpg (11.14 KiB) Viewed 4862 times
Build Log
-- Done, in use --
4 - Dr250/2510/Piezo
2 - OmniTop 12
2 - T48/3015LF (22 inches wide)
2 - T48/3015LF (25 inches wide)
4 - Melded array w8
? - Omni 10
-- Done, in use --
2 - OmniTop 12
4 - Melded array w8
? - Omni 10
In the past I have used some Rockard from Oz - water based, and can be rolled or applied with a hopper gun - might be costly to land here though.
http://www.cannonsound.com.au/search.as ... ds=rockard
...and Hale Manufacturing will apply Line-X if you prep the cabinets - for a price
http://www.haleman.co.nz/shop/Spray+On+ ... INE-X.html
Thanks for the suggestions, that gives at least a few meaty tracks to explore.
I'll pop at the local hardware store to see what's doable in terms of price and availability.
From the plans and rough conversions in metric units, I'd get that 2L would do for a T39?
- Harley
Good lucklalexb wrote:I'll pop at the local hardware store to see what's doable in terms of price and availability.
In the mean time learn some carpeting skills.
I wasn't even convinced myself of any potential success, to be honest...Harley wrote:Good lucklalexb wrote:I'll pop at the local hardware store to see what's doable in terms of price and availability.![]()
So I popped, I saw, and found nothing,... at all, despite it being from the Mega breed.
Truck bed liners, yeah good idea, except that far away from the Land of the Happy Motoring, there isn't that many bed trucks to line to make it the cheap and widely available alternative solution
On my web searches, I found something like those rubber paints from http://www.reidpaints.co.nz/shop/paint/ ... BLACK.html, just wondering if I should give it a go... at least it's black, thick and water(or beer)proof.
I'm putting the corners in anyway, it can stay unfinished for a bit...
You're not going to get it at Mitre 10, but you will get it here -
http://www.completepaints.co.nz/product ... =PAU900501
- Harley
A friend of mine tried that rubberised stuff. It's not bad, but I would say just OK. I decided against using it though as it does not look good for long term use.lalexb wrote:Harley wrote:I wasn't even convinced myself of any potential success, to be honest...
....On my web searches, I found something like those rubber paints from http://www.reidpaints.co.nz/shop/paint/ ... BLACK.html, just wondering if I should give it a go... at least it's black, thick and water(or beer)proof.
Scorpion Coatings have a set up in Australia and I tried to get the agency here but missed out. Then the newly appointed NZ distributor contacted me just before Christmas promising me the earth, free trials bla bla bla - still haven't heard back from him.
Scorpion is a good contender for Duratex BUT it's hellishly expensive - works out to something like $250 a cab for a couple of coats going by the info I could gather.
Yeah I saw this one, but still a 100+ finish option.decibel wrote:You're not going to get it at Mitre 10, but you will get it here -
$99 at http://www.totalbodyshop.co.nz
That's still an option and actually one of the bests, but I'd like to search cheaper alternatives too.
Maybe I'll prime and wait...
Did you manage to find any other alternatives?
With a risk of hijacking the thread, does anyone know of any good sources of carpet suitable for cover a cabs in NZ?
I'm more in the wait & see mode at the moment. (essentially, a wait and enjoy the sound).
I'll give a go to http://www.reidpaints.co.nz/shop/paint/ ... BLACK.html, at least on another box I don't care much about and maybe on the horn mouth, and I'll see from there. I'll let you know if the finish is acceptable.
There's obviously some speaker carpet at JayCar, that's what I've used on my OT12, but being expensive and not really great, I'll pass going for that on the T39. Even if having both cabs matching in terms of finish would be something desirable. (I'd rather redo the OT12...)
There's probably some good material to be found in the places that do upholstery for boats or caravans, but I don't really know where to look at.
Lack of time too.
Lack of time too.
I'm about two weeks off finishing a pair of T39's so am starting to think about covering them.
Yeah, I'm not sure about the carpet option, I suspect the good stuff isn't avaialble in NZ and at .50 exchange rate its gonna cost a bit getting it in from the states.
I am in the auto industry so I will see what I can find in the way of tough paint.
Are you happy with your sound (Music Man?) thru the BFM cab's?
Cheers
Cheers
