Jack 10 Lite
T_Gowan
Jack 10 Lite
#1 Post by T_Gowan »
Started cutting for 2 with another 2 planed. Taking pictures but nothing post worthy yet. Its been in the plans for over 2 years but had to make the first step and buy the ply. Will be full melded array for the first 2 , partially for bass but want them to be PA capable.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
T_Gowan
Re: Jack 10 Lite
#2 Post by T_Gowan »
First question, of many to come. When gluing the front horn braces that go directly on the bottom and top panels. Is it ok to use white carpenter glue for these as they are flat to the panel. Just thought it might be easier to get them flat, tight to the panel.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Re: Jack 10 Lite
#3 Post by Bill Fitzmaurice »
You may, but it's got to be airtight.
Re: Jack 10 Lite
#4 Post by Bruce Weldy »
T_Gowan wrote: Tue May 27, 2025 9:11 am First question, of many to come. When gluing the front horn braces that go directly on the bottom and top panels. Is it ok to use white carpenter glue for these as they are flat to the panel. Just thought it might be easier to get them flat, tight to the panel.
I wouldn't. Unless your cut is dead-on 90 degrees (or whatever the slant is on the Lites), there will be some wiggle when you square it up between the top and bottom. That's where you could possibly get a leak. Not worth it....use the PL everywhere. The squeezeout proves that it's airtight.
T_Gowan
Re: Jack 10 Lite
#5 Post by T_Gowan »
The speaker pole top hat is quite forward with the speaker behind it. Is it to clear the speaker frame?
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
T_Gowan
Re: Jack 10 Lite
#6 Post by T_Gowan »
Just thinking ahead. What radius can you do on the edges of 1/4 inch material on Lite boxes. And are there stackable corners that work on these?
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Re: Jack 10 Lite
#7 Post by Bruce Weldy »
T_Gowan wrote: Fri Jun 06, 2025 8:59 am Just thinking ahead. What radius can you do on the edges of 1/4 inch material on Lite boxes. And are there stackable corners that work on these?
Probably be hard to find corners for 1/4". But, what you could do is put a 1/4" plate on the outside surfaces where the corners go (say 2"x3"). That would give you a 1/2 thickness just at the corners and you can use the standard 3/8" roundover.
I think it would look pretty cool too....beefy corners.
Re: Jack 10 Lite
#8 Post by Bill Fitzmaurice »
3/8 radius plastic corners will work with a 1/4 radius chamfer. They're not ideal but they'll do.
Keryn O'Shea
Re: Jack 10 Lite
#9 Post by Keryn O'Shea »
T_Gowan wrote: Fri Jun 06, 2025 8:59 am ...And are there stackable corners that work on these?
These have a 3mm radius, and are stackable
https://www.penn-elcom.com/au/2-leg-bla ... ius-c1225k
T_Gowan
Re: Jack 10 Lite
#10 Post by T_Gowan »
Test post. did the rotation but didn't need to.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
T_Gowan
Re: Jack 10 Lite
#11 Post by T_Gowan »
Just doing a set or 2 a day. Doing 1 box now to make my mistakes on it lol.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Re: Jack 10 Lite
#12 Post by Tom Smit »
Nice progress!
T_Gowan
Re: Jack 10 Lite
#13 Post by T_Gowan »
Thanks!
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
shane2943
Re: Jack 10 Lite
#14 Post by shane2943 »
Looking GREAT so far!
T_Gowan
Re: Jack 10 Lite
#15 Post by T_Gowan »
Got my top hats, tweeters. Thinking about my next move as I'm at work now :(
Are the crossover components the same as the DR200? I think I have a spare set from my old build.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
