High priced Hifi cabling
Keryn O'Shea
Are they worth it? Is there a big difference over just good quality gear? I understand cheap HDMI would be a false economy..
Re: High priced Hifi cabling
High price cables are the #1 scam in audio, even with respect to HDMI. Digital transmission is immune to all of the gremlins that high priced HDMI supposedly addresses.
+1Bill Fitzmaurice wrote: ↑Thu Mar 09, 2023 7:30 am High price cables are the #1 scam in audio, even with respect to HDMI. Digital transmission is immune to all of the gremlins that high priced HDMI supposedly addresses.
But that said, there is a difference between the crap and the good stuff. And, it's not price that sets them apart necessarily. In mic cables and signal/guitar cables - it's always the connectors that are used and the shielding on the cable that makes the difference with Pro Audio and Live Sound stuff.
In the Hi-Fi world - snake oil is what keeps that industry going.
+1 on connectors and shielding for pro stuff
In all the impressive car audio systems I've ever done (It's not a ton, maybe 10) I can't tell any difference between the "throw away" RCA cables that used to be included with every piece of audio gear and high end Monster Cable type products. Obviously, the high end stuff looks better in a show quality install. But, in a system thats not meant to be looked at, I just use the least expensive RCA option.
There is a difference between crap and good stuff, but good stuff doesn't cost a lot. $1.50 a foot and $5 per connector gives as good a result as you can get. Where speaker cable is concerned zip cord is the performance standard in the home, rubber jacketed type SJ is in pro-sound.
Absolutely!Bill Fitzmaurice wrote: ↑Thu Mar 09, 2023 4:53 pm There is a difference between crap and good stuff, but good stuff doesn't cost a lot. $1.50 a foot and $5 per connector gives as good a result as you can get. Where speaker cable is concerned zip cord is the performance standard in the home, rubber jacketed type SJ is in pro-sound.
I build mic cables all the time for local players and venues for $8 ($4 per connector) plus .40/ft....that's Neutrik connectors and Rapco Horizon cable. $12 for a 10 footer and $16 for a 20. To buy the equivalent online is at least twice that price.
Just got home from a venue that I built 32 mic cables for a couple of years back.....12 are missing and we keep 'em in a locked drawer. I think we need to change the combination on the lock. So, I've got to build some more cables before St Patty's day.
Soldering is cathartic for me......either that or the fumes get me high.....
Keryn O'Shea
Excellent, thank you Bill!Bill Fitzmaurice wrote: ↑Thu Mar 09, 2023 7:30 am Digital transmission is immune to all of the gremlins that high priced HDMI supposedly addresses.
So it would seem mate, quite a bit ofBruce Weldy wrote: ↑Thu Mar 09, 2023 8:41 am In the Hi-Fi world - snake oil is what keeps that industry going.
My SR9600 has sadly bitten the dust, time for a new receiver & I was thinking of fancy cables... glad I asked, thank you Gents
As always,
Our prices are astronomical for everything, signal leads included.
I've managed to find some half reasonable pricing on Neutrik connectors (and working on some wholesale pricing), but the higher quality cable is another thing entirely.
Mogami, Canare and Belden, even in bulk, are almost out of reach for low end players like myself.
Having said that, for home hifi, over the years for signal cables, i adopt much the same attitude as I have for unbalanced leads in my PA.
ie Short as possible, higher copper counts and good screening, with sturdy connectors.
I will make short RCA's to connect components, if they don't need to be standard lengths like 1m, 1.5m, 2m...
That tends to satisfy a balance between stupid spending and snake oil.
We worry about snakes a lot in Australia...
Keryn O'Shea
Nice, can you recommend a supplier for bits to build RCAs Grant?
If I were to go the way of building a system of Toslink/Optical cable from my settop box to a MiniDSP FLex or SHD with analogue outputs, would I be losing any SQ using RCAs to a Marantz MM7025 stereo amplifier? Or should I opt for the balanced TRS outputs? Can TS cables be used in TRS input sockets? Reason I ask is if I can use male TS to RCA adaptors in the Flex TRS inputs, I can then still plug in my Dj decks/iPod.
TRS balanced is inherently better than RCA unbalanced, but only when used with a balanced output and input.
Hey mate,Keryn O'Shea wrote: ↑Sat Mar 11, 2023 4:19 pmNice, can you recommend a supplier for bits to build RCAs Grant?
Funny you ask, it's been ages and when I went looking for what I used to use cable wise, I couldn't find it!
So, I would use this cable:
https://store.cliff.com.au/instrument-c ... cable.html
You'd have to heat shrink a pair together though.
And since you're there:
Get their Amphenol RCA's while you're at it:
https://store.cliff.com.au/49-rca-plugs
Toslink is good up to 5m. If you need an up to 5m run, I would consider that, but if all your runs are less then 1m then get enough cable and connectors as above to custom make and link it all up. Good quality low loss short RCA's should be fine. Toslink may be a WOFTAM. Toslink /fibre optics have come down a lot in price, but you still get what you pay for.Keryn O'Shea wrote: ↑Sat Mar 11, 2023 4:19 pm If I were to go the way of building a system of Toslink/Optical cable from my settop box to a MiniDSP FLex or SHD with analogue outputs, would I be losing any SQ using RCAs to a Marantz MM7025 stereo amplifier? Or should I opt for the balanced TRS outputs? Can TS cables be used in TRS input sockets? Reason I ask is if I can use male TS to RCA adaptors in the Flex TRS inputs, I can then still plug in my Dj decks/iPod.
What Bill said re TRS...
As long as we've gone down the snake oil rabbit hole: how BS are speaker cable risers? (Allegedly eliminate static charge from interference from carpeting.)
If you believe they do anything I'd like to speak to you about Bernard L. Madoff Investment Securities.
Lifting speaker cables off a damp concrete floor or wet ground outdoors has value, as they can suffer capacitive losses. But static charge from a rug? Rugs don't hold static charge. Objects that are rubbed against a rug can acquire a static charge, but even if you did so with a speaker cable it wouldn't affect the sound, since static charges are DC, not AC.
Keryn O'Shea
And then there's this type of thing..
Just by looking at it I can tell the rear chamber is much too large and the horn path is too short. I'd say he saw a picture of a 1920's vintage Western Electric theatrical horn and used that as his inspiration but didn't use HornResp to engineer it. It looks interesting, but that's the only positive comment I can make about it.
