AT 10" driver choice
Re: AT 10" driver choice
#16 Post by Tom Smit »
Anton, I believe that is the rig. I remember a photo of that rig beside a home-built stage with dirt at the front of the stage, and trees in the near-background. I think there was an OT12(?) at the roof on either side of the stage.
#17 Post by Seth »
Tom Smit wrote: Fri Feb 05, 2021 11:08 pm Anton, I believe that is the rig. I remember a photo of that rig beside a home-built stage with dirt at the front of the stage, and trees in the near-background. I think there was an OT12(?) at the roof on either side of the stage.
viewtopic.php?t=3533
#18 Post by Seth »
#19 Post by AntonZ »
I had forgotten about those pics. Now that I see them I remember these too. Good find!
#20 Post by Tom Smit »
Seth...BINGO!
Good job! How did you find them?
Anyone notice the sandbags on top of the AT pile? They were placed there in order to keep that pile from walking.
#21 Post by Seth »
Tom Smit wrote: Sun Feb 07, 2021 12:16 am Seth...BINGO!
I just did a google image search for "6 autotubas". The pics showed in the results, but wouldn't link with the "copy image URL" function at first. So, I just did a screenshot, crop, and reupload. But, then I inspected the images digital history a little and was able to find an image address that worked and was able to link directly to them.
Line92
#22 Post by Line92 »
Then it seems like i will be very pleased with the 20" autotuba hehe!
Thanks for the help and cool pics! 😁
SLA PRO 4X6
T60 2x20"
Labgruppen fP6400. fP2400Q. DBX Driverack PA2
TLAH
AT 20"
TRT
#23 Post by Tom Smit »
Alright! I did some digging and found the thread. The first post has the details.
Line92
#24 Post by Line92 »
Does anyone know the recommended Highpass filter setting and voltage limit of the Autotuba with the Dayton LS10-44 or a similar driver with more than 10mm Xmax? Cant find it in my plans.
I did go with the GZ sub and currently making progress, slowly haha.
It will be wired to 4ohm. Is 25V to much?
SLA PRO 4X6
T60 2x20"
TLAH
AT 20"
TRT
It's not in the plans because auto sound rigs don't have limiters. 28v high passed at 40Hz would be safe.
Line92
#26 Post by Line92 »
Thank you for reply.
Loctite will be used 8)
And those nuts have PL before i punched them into place.
It takes a long time to cure and expand at 8°C
Its -19°C outside and my garage that is a old stable is not very isolated :lol:
SLA PRO 4X6
T60 2x20"
TLAH
AT 20"
TRT
#27 Post by Seth »
Line92 wrote: Mon Feb 15, 2021 10:17 am Loctite will be used 8)
That's looking good Linus :thumbsup:
Keep in mind that if you ever need to replace the driver, the use of loctite could cause the inserts to spin/strip in the wood... which would be a HUGE headache. If it were me, I'd use screws and screw retention blocks (as per the plans) instead of nut inserts an bolts. And if I did use inserts and bolts, I'd use lock washers and forego any loctite... even the purple loctite 222.
Also, PL cures with moisture/humidity. If it's taking longer than you want to cure, you can dab the area with a moistened paper towel to speed things up a bit.
As far as the voltage and limits go... For reference, I have run my 2x8 (parallel wired) TAT very hard, unlimited and over powered without failure. It has bottomed out the voice coil on the backing plate a few times, so there's obviously value in limiting voltage and/or high-passing bottom frequencies. But, again, no failures. I never measured, but the amp I was using in that system should have been very capable of supplying at least 45 volts. The amp killed a few alternators, but never the inexpensive MCM drivers.
I built a 2x8 (parallel wired) TruckTuba and powered that one with a 28v (IIRC) signal without a high-pass filter and performance measure in car was fairly flat all the way down to 20Hz (and below). Plenty loud for most listeners too.
Line92
#28 Post by Line92 »
Seth wrote: Mon Feb 15, 2021 11:49 am
Thanks for the tip Seth! Could save me that headache.
I will go with the lock washer, and maybe check bolts after a few hours of use to be sure it is secured and tight.
Yeah i use a glass of water and brush the areas that will be joined together, otherwise it wont cure at all now, very dry inside my garage to!👍
Haha oh wow! Those MCM seem to be good quality then! To bad they are not avaliable in EU, maybe for order but i think that would be very expensive.
Cool then i guess that even with like 12db 35-40hz HP it will go a bit deeper when it is in the car? 👍 i want to feel that 30hz 8)
SLA PRO 4X6
T60 2x20"
TLAH
AT 20"
TRT
#29 Post by Seth »
If you haven't already, you may consider breaking the driver in while it's mounted to that baffle so that you can verify that the surround isn't going to come into contact with the baffle at higher excursions. If it does make contact with the baffle, you'll likely be able to round over or bevel the edge from the driver side to make clearance.
Line92
#30 Post by Line92 »
Seth wrote: Mon Feb 15, 2021 2:42 pm 20210213_163556.jpg
I have, and it doesnt hit anything, after i sanded it down slightly hehe :cowboy:
I ran a 25hz test tone with up to about 12V max, it seem to hit its claimed Xmax of 13mm with around 9-10V in free air, no noise or sound what so ever from it! :hyper:
With 12V 25hz it seems to exceed it, crazy excursion, i would estimate the cone travel to be around 35mm p-p at those levels. Still only minor blowing noise from the coil vent 👍
Would be intresting to put the driver in a sealed cab with the same volume as the horn, just to see at what levels it start to be sketchy :lol:
But then to me it feels like thats not going to provide correct information or data for its use, i also guess that the horn itself makes some kind of "back pressure" so the cone doesnt move as much, depending on the frequenzy input and horn lenght...?
SLA PRO 4X6
T60 2x20"
TLAH
AT 20"
TRT
