The most noticeable part for me with the 2x6 SLA Pro's I built was way more detail in the highs than any other speaker we've used. Good because I'm hearing things I didn't before. And BAD because... I'm hearing things I didn't hear before. LOL Overall a good experience. I'd rather have the capability to hear everything I want. I can always filter out the undesirable elements. Which, in my case is increased sylibence... the "S's" (esses) really jump out.Radian wrote: ↑Tue Aug 04, 2020 2:39 pm Got the tweeters glued and screwed. Cured over night and have been running signal through them this morning.
One thing I noticed right away with the sound, they're holographic. Anyone else experience this? I mean, I'm hearing discernible layers of depth in the mixes...the kinda of Z-axis behavior I've experienced on Danley and Vandersteen stuff.. maybe not so "in-your face" obvious like them, but subtle and present no less... and that's simply using my Walkman or an iPad so far.
I haven't even broken out the good gear yet.
Radian's SLA Pro 4x6 build
Re: Radian's SLA Pro 4x6 build
I totally agree on the option to filter out. That's always a plus.
Although these certainly still require EQ to sound their best, it wouldn't take much at all to adjust. Here I have them playing straight off the iPad, no EQ applied... high-sensitivity FTW.
Careful with the volume near the end when the Metal track starts. It's more quiet at first which might tempt someone to turn it up, but I eventually stick the mic's right between the cabs which really spikes the level.
Just waiting for new grills to close this out, then it's on to T48's
Beautiful recording Radian, as usual
What are the first two songs?
Thanks Seth!
First one is an upload from OmegaMetroid93:
and the second is a clip of Patti Broussard playing her Array Mbira:
Grills came in yesterday from a 3rd party fabricator, but am once again sorting out another fitment issue.
Other than finishing out the T48's, I'm realizing that I'm gonna need a better method to organize cable storage, the rig needs a digital mixer (master volume), and that the K&M Tilt locks are a great idea on paper, but I think Nimrod's BT-12 might be in order.
Revisiting the custom replacement grills I received from Reliable Hardware.
I was worried at first because these grills fit significantly tighter than the ones I had formed at work, which dropped right in. However, once I figured out that they fit so tightly in the baffle that they required no further fastening than somewhat brutishly press-fitting them into place, I was relieved.
I finally got around to ordering another batch of grill foam too, and read up on how Mr. Weber tackled getting the material to stick well enough to the grills. Hopefully the undercoating method works better than the contact adhesive I had tried previously. We'll see. If no luck this time around, I'll use them sans foam. Fingers crossed, but even without the foam, the new grills look great!
I'll be posting the ones I made in the For Sale section once the foam is re-installed.
Grills turned out better than I was expecting. Was biting my fingernails there during the cure.
These SLA Pro are done now. Complimentary subs are currently in the works.
They look great! Nice job....
Those came out sooooo good looking. Great job Radian
They look great
jemo1234567890
Good job Radian
how are your grills holding because I can't see any screw? Magnets?
Do you know which subs you will build for your SLAs?
Thanks all. Standing on the shoulders of giants here. Couldn't have done it without spending a ton of time in the Tips, Techniques, Suppliers section and checking out previous builds.
They are press-fit into place. The interference between the Line-X textured finish along the baffle and the vinyl coating of the grills is what's holding them. Rather tightly, I might add.jemo1234567890 wrote: ↑Fri Jan 22, 2021 7:15 am how are your grills holding because I can't see any screw? Magnets?
Titan 48's. I've got a build thread on them going already.jemo1234567890 wrote: ↑Fri Jan 22, 2021 7:15 am Do you know which subs you will build for your SLAs?
