36" T48 x2
Preston
Re: 36" T48 x2
#16 Post by Preston »
shawn_g wrote:Very nice. Have you listened to them yet?
Not yet (but I do have a pair of 24") These just got the second side attached. Still need to do all the finish prep, Duratex, install drivers, leak test, etc..
Preston
Re: 36" T48 x2
#17 Post by Preston »
Bondo and sanding last night. Should be ready for a coat of paint (black latex undercoat before Duratex) by Sunday. I do have a question: I always fill all the little holes from the brad nailer, but I suspect that it may not be necessary. Thoughts?
CoronaOperator
Re: 36" T48 x2
#18 Post by CoronaOperator »
Preston wrote:Bondo and sanding last night. Should be ready for a coat of paint (black latex undercoat before Duratex) by Sunday. I do have a question: I always fill all the little holes from the brad nailer, but I suspect that it may not be necessary. Thoughts?
Depends on how many coats duratex you use. I fill them as I only use 2 coats of duratex (no primer) and the duratex will fill most but not all brad holes. Really, I would be the only one to notice them. Depends how OCD you are.
Preston
Re: 36" T48 x2
#19 Post by Preston »
Filling and sanding done, coat of flat black paint applied. Paint is still wet in photo.
Black Boxes.jpg (20.17 KiB) Viewed 2273 times
Preston
Re: 36" T48 x2
#20 Post by Preston »
Duratex is on. 3" Casters and protective corners installed. Hope to install the 1.5" front feet and then drivers and jack plates followed by leak testing tonight.
casters and corners.jpg (20.85 KiB) Viewed 2243 times
Preston
Re: 36" T48 x2
#21 Post by Preston »
Got a little done yesterday, installed the input jacks
Input Jack.jpg (19.76 KiB) Viewed 2220 times
Preston
Re: 36" T48 x2
#22 Post by Preston »
Mounted the drivers
Driver Mounted.jpg (18.86 KiB) Viewed 2220 times
Preston
Re: 36" T48 x2
#23 Post by Preston »
Front view, ready to leak test driver
Front View Access off.jpg (16.17 KiB) Viewed 2220 times
Preston
Re: 36" T48 x2
#24 Post by Preston »
Here they are. A pair of newly minted 36" T48 next to the vintage (original plans) 24" T48. Disclaimer: I did not build the 24's, I bought them used several years ago. I did spend the weekend retrofitting the mouth braces (they were not installed), checking driver tightness, leak testing, changing casters, front feet, and corner protectors, and applied a fresh coat of Duratex. Just ordered kits from Leyland to build one more pair of 18" wide for smaller venues when space is tight.
Re: 36" T48 x2
#25 Post by Bruce Weldy »
Very nice....
chrisj360
Re: 36" T48 x2
#26 Post by chrisj360 »
Looking very good. Nice build!
2 x 21" T30's with Lab12's
2 x 28" T30's with Lab12's
Re: 36" T48 x2
#27 Post by Tom Smit »
Good job!
Once you get the 18" cabs completed, you will have quite a bit of versatility.
88h88
Re: 36" T48 x2
#28 Post by 88h88 »
Tom Smit wrote:Good job!
Once you get the 18" cabs completed, you will have to stack them all and make everyone within half a mile deaf.
:D
Preston
Re: 36" T48 x2
#29 Post by Preston »
Pics or it didn't happen. Freshly minted pair of 18" wide T48. 3015lf loaded.
T48 18 inches.jpg (13.29 KiB) Viewed 2052 times
Re: 36" T48 x2
#30 Post by Tom Smit »
:D
Preston wrote:Pics or it didn't happen. Freshly minted pair of 18" wide T48. 3015lf loaded.
Apparently, there are going to be deaf people around you. :lol:
:clap: ....my actual quote, hehe...
Good job!
