Not yet (but I do have a pair of 24") These just got the second side attached. Still need to do all the finish prep, Duratex, install drivers, leak test, etc..shawn_g wrote:Very nice. Have you listened to them yet?
36" T48 x2
Re: 36" T48 x2
Re: 36" T48 x2
Bondo and sanding last night. Should be ready for a coat of paint (black latex undercoat before Duratex) by Sunday. I do have a question: I always fill all the little holes from the brad nailer, but I suspect that it may not be necessary. Thoughts?
CoronaOperator
Re: 36" T48 x2
Depends on how many coats duratex you use. I fill them as I only use 2 coats of duratex (no primer) and the duratex will fill most but not all brad holes. Really, I would be the only one to notice them. Depends how OCD you are.Preston wrote:Bondo and sanding last night. Should be ready for a coat of paint (black latex undercoat before Duratex) by Sunday. I do have a question: I always fill all the little holes from the brad nailer, but I suspect that it may not be necessary. Thoughts?
Re: 36" T48 x2
Filling and sanding done, coat of flat black paint applied. Paint is still wet in photo.
- Attachments
- Black Boxes.jpg (20.17 KiB) Viewed 2278 times
Re: 36" T48 x2
Duratex is on. 3" Casters and protective corners installed. Hope to install the 1.5" front feet and then drivers and jack plates followed by leak testing tonight.
- Attachments
- casters and corners.jpg (20.85 KiB) Viewed 2248 times
Re: 36" T48 x2
Got a little done yesterday, installed the input jacks
- Attachments
- Input Jack.jpg (19.76 KiB) Viewed 2225 times
Re: 36" T48 x2
Front view, ready to leak test driver
- Attachments
- Front View Access off.jpg (16.17 KiB) Viewed 2225 times
Re: 36" T48 x2
Here they are. A pair of newly minted 36" T48 next to the vintage (original plans) 24" T48. Disclaimer: I did not build the 24's, I bought them used several years ago. I did spend the weekend retrofitting the mouth braces (they were not installed), checking driver tightness, leak testing, changing casters, front feet, and corner protectors, and applied a fresh coat of Duratex. Just ordered kits from Leyland to build one more pair of 18" wide for smaller venues when space is tight.
- Attachments
- Family.jpg (14.71 KiB) Viewed 2188 times
Re: 36" T48 x2
Very nice....
Re: 36" T48 x2
Looking very good. Nice build!
2 x 21" T30's with Lab12's
2 x 28" T30's with Lab12's
Re: 36" T48 x2
Good job!
Once you get the 18" cabs completed, you will have quite a bit of versatility.
Re: 36" T48 x2
Tom Smit wrote:Good job!
Once you get the 18" cabs completed, you will have to stack them all and make everyone within half a mile deaf.
Re: 36" T48 x2
Pics or it didn't happen. Freshly minted pair of 18" wide T48. 3015lf loaded.
- Attachments
- T48 18 inches.jpg (13.29 KiB) Viewed 2057 times
Re: 36" T48 x2
88h88 wrote:Tom Smit wrote:Good job!
Apparently, there are going to be deaf people around you.Preston wrote:Pics or it didn't happen. Freshly minted pair of 18" wide T48. 3015lf loaded.
Good job!
