Table Tuba 18 inch starts
andrewtilsley
#1 Post by andrewtilsley »
Pulled the trigger on this project for stereo music listening.
At this stage, I'll use one single horn to partner with my Azura horn system.
Target xover point is 80Hz.
I was lucky to have access to lovely Euro birch ply....9 layers per half inch. Zero warping will make for an easy build.
Opted for Tang Band driver, 8 inch.
Andrew
Birch ply.jpg (8.89 KiB) Viewed 3622 times
commander_dan
Re: Table Tuba 18 inch starts
#2 Post by commander_dan »
Noice! I am currently convincing a friend to have a crack at a T18, I'll be keeping an eye on your progress!
6 T30 (24", 3012LF)
2 OT12 (MA, 3012HO)
2 T24 (18", 3010LF)
Running:
DCX2496
XTi 2002
XTi 4002
TRAKTOR Z2
TECHNICS 1210 Mk5's
#3 Post by Grant Bunter »
Nice,
Jealous of you being able to access birch ply!
What happened to your plan to build a THT or dual loaded T24's?
andrewtilsley
#4 Post by andrewtilsley »
Grant Bunter wrote:Nice,
Man, the decision killed me. But I made my choice based on a couple of factors, including:
Tuba18 was/is designed for max output…and operates better in higher frequency range.
Tuba18 would not have fitted in my Walnut outer cabs (I was out by about one inch).
THT ideal for home theatre, due to massive size and bass depth…plus harder to fit in my stereo listening set up.
As such, the TT rang the right bells…size, performance etc. I can always build a second one if needed.
It’s a strange sensation off-loading x2 18-inch pro subs for a single 8-inch sub….! But, I’m confident…besides, I love horns…and I simply want an all horn rig…and I’m ¾ way there.
Now, what to do with the mid bass range of 80-600Hz....?! :broke:
caddylackn
#5 Post by caddylackn »
[/quote]
It’s a strange sensation off-loading x2 18-inch pro subs for a single 8-inch sub….[/quote]
....and off-loading the big pro amp that ran the 2x 18's.
You will only need a little 200w or 250w amp now.
16.5" AT w/ Infinity 860w
TLAHs w/ 9 mids & 16 tweets
16" TAT w/ Infinity 1060w
18" TT w/ Dayton DCS-205-4
5.5" TrT w/ DCS-205-4
T-18 w/ DCS-205-4
DR200s
andrewtilsley
#6 Post by andrewtilsley »
You will only need a little 200w or 250w amp now.[/quote]
Normally true, but I'm using a quality six channel amp from Holton Precision Audio (Tasmania)...so that will stay in play.
andrewtilsley
#7 Post by andrewtilsley »
Screw holes and chamfers made today.
drill bit to chamfer.jpg (9.15 KiB) Viewed 3446 times
andrewtilsley
#8 Post by andrewtilsley »
Started glue up tonight.
Using screws to secure each panel...as they've been precision cut, the screws pull the panels perfectly square. Easy.
I haven't added baffle panel...so I'm completing it out of strict order.
Poly glue foaming up nicely.
Two panels need a few mm trimming. All the angles have worked out fine...except one panel where I cut the two angles the wrong way. Luckily, I have some spare ply to fix.
See pic to show how the levels our all true.
Used iPhone compass app to check vertical true.
iphone level.jpg (13.71 KiB) Viewed 3414 times
glue up 2.jpg (11.12 KiB) Viewed 3414 times
edges line up.jpg (8.43 KiB) Viewed 3414 times
glue foaming.jpg (6.99 KiB) Viewed 3414 times
bassmonster
#9 Post by bassmonster »
You're using PL Premium, right? That doesn't look like PL squeeze-out to me for some reason.
andrewtilsley
#10 Post by andrewtilsley »
bassmonster wrote:You're using PL Premium, right? That doesn't look like PL squeeze-out to me for some reason.
Yes. That's not a good pic. Other sections of glue have bubbled up to be over half inch thick outside the join.
andrewtilsley
#11 Post by andrewtilsley »
I meant to attach this pic.
foam glue 2.jpg (6.33 KiB) Viewed 3375 times
#12 Post by Grant Bunter »
Don't be to harsh lol. PL premium, as far as I've been able to ascertain, is only available from one source here.
And minimum order is by the box.
So you will perhaps find some Aussie builds with Sika product or similar...
andrewtilsley
#13 Post by andrewtilsley »
Phew.
I've built dozens of horns...and this product is excellent.
I debated getting the thicker Sika product (used with tube gun), but it was less economical.
shawn_g
#14 Post by shawn_g »
Nice looking build so far!
caddylackn
#15 Post by caddylackn »
andrewtilsley wrote:Started glue up tonight.
It is very important that you test fit the driver into the baffle opening with all the screws to check for clearance and rubbing and make clearance adjustments if needed. Don't install so many panels that you cannot still do this.
T-18 w/ DCS-205-4
DR200s
