djtrumptight wrote:The finished products with the new Baffle's,front page worthy...
Is there a bigger gap after below top 2 tweets in your SLAs, or is it just a trick of the photography?
Yep,thats a gap I don't know how my template ended up with a gap in it but its cool,no one will be in my bedroom but me and my wife (unless she has a boyfriend ).
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
djtrumptight wrote:I'm re-doing the Baffles to the flat array's,as you can see they are considerably lighter than the rest of the build.I was going to use Tung Oil instead of stain but after doing the baffles I determined that it was much too light so I went with Red Oak #215 stain which didn't cover the Tung Oil too good.I already started re-doing them.The rest looks real nice.The wood is 1/2" BB.I also spaced the drivers out a small amount to give me enough room to route horns for the midbasses.
Man!! What a beautiful job on that finish, absolutely gorgeous!!
1 x T18...18" wide, mcm subwoofer
1 x AT...15" wide, Alpine 10" S- series subwoofer
Just take your time and keep in mind that u r gonna stain the end result and for that reason i used brad nails instead of screws,the wood filler isnt so apparent when covering up brad nail holes.
2 SLA HT systems
2 SLA Pro's
biggerrigger wrote:What drivers did you use on your SLA's?
Sorry for not responding,i never seen your question.I used some 3" closeouts from madisound,i'm thinking about building another one using just 6 drivers in a 7.2 configuration.
2 SLA HT systems
2 SLA Pro's
