Yep,thats a gapescapemcp wrote:Is there a bigger gap after below top 2 tweets in your SLAs, or is it just a trick of the photography?djtrumptight wrote:The finished products with the new Baffle's,front page worthy...
SLA and Tuba 18 build
djtrumptight
Re: SLA and Tuba 18 build
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
djtrumptight wrote:I'm re-doing the Baffles to the flat array's,as you can see they are considerably lighter than the rest of the build.I was going to use Tung Oil instead of stain but after doing the baffles I determined that it was much too light so I went with Red Oak #215 stain which didn't cover the Tung Oil too good.I already started re-doing them.The rest looks real nice.The wood is 1/2" BB.I also spaced the drivers out a small amount to give me enough room to route horns for the midbasses.
Man!! What a beautiful job on that finish, absolutely gorgeous!!
1 x T18...18" wide, mcm subwoofer
1 x AT...15" wide, Alpine 10" S- series subwoofer
joeynaeger
Very nice. I have the parts for a couple SLA's and a T18 that I need to carve some time out for. I'll be happy to have mine look half as good!
djtrumptight
Just take your time and keep in mind that u r gonna stain the end result and for that reason i used brad nails instead of screws,the wood filler isnt so apparent when covering up brad nail holes.
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
biggerrigger
What drivers did you use on your SLA's?
4-25" Lab12 loaded T39's
2-DR250's Melded array
2-DR250's Flat array
djtrumptight
Sorry for not responding,i never seen your question.I used some 3" closeouts from madisound,i'm thinking about building another one using just 6 drivers in a 7.2 configuration.biggerrigger wrote:What drivers did you use on your SLA's?
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
Finish is beautiful on the curved center, I like that red oak you used.
Very nice work on the system, I'm jello
djtrumptight
The wood is 1/2" Baltic Birch,i forgot which stain i used.howiez wrote:Finish is beautiful on the curved center, I like that red oak you used.
2 SLA HT systems
2 SLA Pro's
2 SLA HT systems
2 SLA Pro's
