SLA and Tuba 18 build
biggerrigger
Re: SLA and Tuba 18 build
#16 Post by biggerrigger »
I might of missed it but what drivers did you end up going with? Lookin good Trump :clap:
4-25" Lab12 loaded T39's
2-DR250's Melded array
2-DR250's Flat array
djtrumptight
#17 Post by djtrumptight »
I used the Madisound 3" midbasses and Goldwood GT-302 tweeters.
Antonz oddly enough I got the idea to do that on one hole lol.I drilled a hole in the middle with a 3/16 drill bit.i'm about to go tackle the 1" holes and its 5 degree's outside,i will drill holes in all the centers first,that should help.Thanks for the tip.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
#18 Post by AntonZ »
It is not about a hole in the centers, it is about a few holes touching the circle that the hole saw cuts so the saw dust can fall down instead of filling up the circle that the saw is cutting. Sorry if I am not writing it down very clearly, I'm not a native english writer :noob:
jimbo7
#19 Post by jimbo7 »
For drilling smaller diameter holes in wood, a Frostner bit is the way to go. It doesn't saw into wood, it shaves it. So it takes less speed and runs cooler. Plus it makes nice really nice clean holes. It the only thing I'll use to make holes.
Just make sure to have a piece of sacrifical wood underneath to prevent possible chip-out.
djtrumptight
#20 Post by djtrumptight »
I understood what you meant AntonZ,it worked a lot better.
Jimbo I thought about that but the holesaw worked out and I didn't have any tear outs to fill.
2 SLA HT systems
2 SLA Pro's
djtrumptight
#21 Post by djtrumptight »
Not even a Michigan Winter can stop the addiction...
2 SLA HT systems
2 SLA Pro's
djtrumptight
#22 Post by djtrumptight »
The finished products with the new Baffle's,front page worthy...
2 SLA HT systems
2 SLA Pro's
thunderw0lf
#23 Post by thunderw0lf »
Looks nice. My TTLS is almost ready for staining. I know what you mean about the MI winters. I did all the cutting out in the garage and then brought the parts inside and assembled it in the living room.
Drey Chennells
#24 Post by Drey Chennells »
:clap:
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
#25 Post by DJPhatman »
How is that tweeterless curved SLA working for you, djtrumptight?
djtrumptight
#26 Post by djtrumptight »
its working pretty good,i haven't hooked it up to a good 5.1 receiver yet but the SLA's sound ALOT better than the cheap pioneer system its replacing.I still have to order a receiver and a Bash plate amp for the T 18.
2 SLA HT systems
2 SLA Pro's
cbarth
#27 Post by cbarth »
Congrats, looking very,very good!
What drivers did you end up using in those sla's?
Cbarth
djtrumptight
#28 Post by djtrumptight »
2 SLA HT systems
2 SLA Pro's
biggerrigger
#29 Post by biggerrigger »
Lookin good Trump, Man I have some catching up to do. I have all of my SLA drivers just need the time to build the cabs.
escapemcp
#30 Post by escapemcp »
djtrumptight wrote:The finished products with the new Baffle's,front page worthy...
Is there a bigger gap after below top 2 tweets in your SLAs, or is it just a trick of the photography?
