more spinning hurricane nuts
sine143
#1 Post by sine143 »
hey guys. sealing up my latest t48s for the show tmrw, managed to spin 3 hurricane nuts that were epoxied in..... how to i go about getting them out? ive removed all other bolts.... and im trying to get them out so i can fix the problem...
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
Re: more spinning hurricane nuts
#2 Post by DJPhatman »
If you can't reach inside to grab them with vise grip pliers, cut the screws off.
Ryan A
#3 Post by Ryan A »
To avoid in the future use the "security screw" technique pioneered by Harley (I believe) to prevent movement of the hurricane nuts. Also always make sure the bolts go in by hand or with only very slight pressure applied to an allen wrench. Using coarse threaded nuts/bolts works better with less chance of cross threading.
#4 Post by LelandCrooks »
Rotate the drivers, replace all with recex screws.
sine143
#5 Post by sine143 »
had to cut a hole in the top of the sub to remove the 3 spun t nuts. filled with epoxy, coarse threaded screws ftw.
1x bastard XF208
mr.lussier
#6 Post by mr.lussier »
Ryan A wrote:To avoid in the future use the "security screw" technique pioneered by Harley (I believe) to prevent movement of the hurricane nuts. Also always make sure the bolts go in by hand or with only very slight pressure applied to an allen wrench. Using coarse threaded nuts/bolts works better with less chance of cross threading.
That technique is intended for regular t-nuts. Hurricane nuts have a round base.
If you spun hurricane nuts you quite possibly drilled the pilot holes a bit loose. Also, these work best in baltic birch, as the wood is more dense than pine. If properly installed in BB, you can't spin these even if you try to.
Built : 2 x beta8 wedgehorn w/melded array
20'' wide t39 3012lf loaded
still can't decide on tops !
#7 Post by Bruce Weldy »
The technique works just fine with H-nuts.....remember, we are DIYers. Drill a hole in the flange.
