Template Template
tpgreen
Template Template
#1 Post by tpgreen »
Sorry if this has already been posted, but here is a really simple way to build baffle templates.
Only requires routing a circle and cutting some straight edges, screwing them down and routing around them with a top bearing template bit. The inner material is easily removed by plunging the bit.
Once you remove the screws/wood you are left with the master jig.
Michael Ewald Hansen
Re: Template Template
#2 Post by Michael Ewald Hansen »
tpgreen wrote:Sorry if this has already been posted, but here is a really simple way to build baffle templates.
Only requires routing a circle and cutting some straight edges, screwing them down and routing around them. Once you remove the screws/wood you are left with the master jig.
Actually, I haven't seen a jig thread in a long time.. So this is great advice for new builders.. You do need to mention that you need a top bearing template bit for this to be possible :)
I do templates like this with a festool plunge saw and finish cuts with a jigsaw - gives perfect straight cuts aswell and is a bit faster than cutting out all those small pieces imo - but each to their own 8)
Authorized Builder - Denmark
tpgreen
#3 Post by tpgreen »
Good point about mentioning the top bearing template bit(just edited it). I had never owned/used a router before my first BFM build a few months ago.
I found I was way too unsteady with the jigsaw - hence straight edges/circle, which even a novice can conquer with the right tools. With a T55 plunge saw and Jasper Circle jig I can at least cut a straight line and circle.)
#4 Post by AntonZ »
A template to make a template, that would be a meta-template :)
I like it. Thanks for sharing, tp.
Rune Bivrin
#5 Post by Rune Bivrin »
Really like the concept!
You don't really NEED a top bearing bit. Just take a Forstner bit or something similar to drill 4 large holes; then flip the combo and route from the other side.
Top bearing bits seem to be virtually non-existing over here. I've seen them in distributor catalogs but never in retail.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
88h88
#6 Post by 88h88 »
Rune Bivrin wrote:Really like the concept!
I have a bottom bearing bit which mean my template is strapped to the bottom of whatever I'm cutting out. Might look for a top bearing bit.
#7 Post by Michael Ewald Hansen »
I shop all my router bits at something called Wealden Tools in UK - they have an online shop and ship extremely fast all over europe.. Router bits are top top quality and the price is not too bad..
Might be a good tip for other builders in europe/UK :)
http://www.wealdentool.com/acatalog/Rou ... ers_1.html
hifibob
#8 Post by hifibob »
Thats basically how I built all my templates as well.. Good job!!
byacey
#9 Post by byacey »
That's how I did the WH8 baffles, except I used a bottom bearing bit with the template underneath and hogged out the majority of the material first with a sabre saw. The router bit just trims away the last remaining bit of wood and finishes off the cutouts.
T48s
WH8s
SX212
Rune Bivrin
#10 Post by Rune Bivrin »
Michael Ewald Hansen wrote:I shop all my router bits at something called Wealden Tools in UK - they have an online shop and ship extremely fast all over europe.. Router bits are top top quality and the price is not too bad..
And bookmarked!
In build order:
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
#11 Post by LelandCrooks »
