dutch Titan 39
Re: dutch Titan 39
#16 Post by Grant Bunter »
Bas Gooiker wrote: but tonight ill get the mouthbracing in there and the last side panel.
You're just ahead of me on my second pair of cabs Bas.
I wish BB was cheaper and readily available here. Your pics make me think some natural finish cabs would look pretty good...
Patrick Mos
Re: dutch Titan 39
#17 Post by Patrick Mos »
Did i hear someone called shootout? I'll bring the SLApro's, DR200, and T39! Jee!
Authorized Builder
my BFM gear:
2 T39, 27 inch, deltalf loaded ( R.I.P )
2 T39, 27 inch, 3012lf loaded.
2 DR200 beta and asd1001 loaded.
1 Autotuba jbl gto 1002d loaded.
2 Funky looking SLA's....
1 TTLP (acting as a scratching pole for my cats...)
Bas Gooiker
Re: dutch Titan 39
#18 Post by Bas Gooiker »
Finaly had some time off from family & work life....
So finaly finished the first of my 2 titans. Its all about sanding & bondo and after that paint.
As i used the "better safe then sorry" aproach with screws and PL i am looking @'hours & hours of scraping excess glue and filling holes. :bash: I had to use a combination of brute force, and all the clamps within reach to get the last side panel on semi straight. Pictures to prove my progress will be posted tomorrow. :D
@ The other dutchies: Im all up for a dutch / belgium bfm shootout. I hope my second one will be done a bit quicker as i have the baffle and some panels already cut, and the experience from nr 1.
Patrick Mos
Re: dutch Titan 39
#19 Post by Patrick Mos »
This dutchie has to upgrade his dr200 first...I haven't used them for i while, and when i fired one up yesterday, something was off...
Nice Build Bas! the first time you fire up a Titan is something magical...and after a few minutes it turns diabolical... :twisted:
( I feel that the force is strong in this one....)
Authorized Builder
my BFM gear:
Bas Gooiker
Re: dutch Titan 39
#20 Post by Bas Gooiker »
Pictures from the current situation. Tomorrow my tub of Warnex will arive, i hope i have time to paint it tomorrow night.
Patrick Mos wrote:Nice Build Bas! the first time you fire up a Titan is something magical...and after a few minutes it turns diabolical... :twisted:
I have been fighting the urge to put the driver in and take it for a test drive. But i'll wait becouse i know it will stay unpainted for a long time as it will be near impossible to take it apart again.
Plenty of holes to fill.
Front, all primered and ready
Caulk all around the inside of the back chamber, no leaks here.
Re: dutch Titan 39
#21 Post by AntonZ »
Patrick Mos wrote:Did i hear someone called shootout? I'll bring the SLApro's, DR200, and T39! Jee!
What drivers did you use in your SLA-pro Patrick? I am thinking about replacing my 4x OT12 with a pair of SLA-pro. I don't think the Dayton 6 is available over here. The price tag on the recommended Alpha 6 drivers is somewhat prohibitive (as is shipping the Dayton alternative from Parts Express to Europe).
Disco-inferno
Re: dutch Titan 39
#22 Post by Disco-inferno »
A shootout sounds nice :hyper: , although I'm not using any BFM gear right now. I own a couple of rear hornloaded cabs (microscoop style) which I'm pretty curious about how they would compare to T39/48.
The cabs are currently up for sale along with some other equipment to raise funds for my future builds :mrgreen: .
Bas Gooiker
Re: dutch Titan 39
#23 Post by Bas Gooiker »
AntonZ wrote:What drivers did you use in your SLA-pro Patrick? I am thinking about replacing my 4x OT12 with a pair of SLA-pro. I don't think the Dayton 6 is available over here. The price tag on the recommended Alpha 6 drivers is somewhat prohibitive (as is shipping the Dayton alternative from Parts Express to Europe).
You might find something here http://www.europe-audio.com/Producten_c ... ep_a_ID=66Monacor brand. There are also the Fane Sovereign 6-100 @ 34 euro with Thomann, though they miss the rising midrange responce of the Alpha's. I dont know if that is necsessary for the SLA pro. Its not mentioned in the plans.
Patrick Mos
Re: dutch Titan 39
#24 Post by Patrick Mos »
@antonZ:
I used the alpha's...50 euro a pop, give or take. i'm looking for some replacements, but they are hard to find. maybe the fane 6-100 or the conrad speakers. I'll order some, and test it. They sure rock with the apha's! maybe a little harsh in the high's, but hey, that's why we have eq's.
@ Bas ( or is it Bass? ;-) )
wait just a little bit longer....a little bit. the longer you wait, the better it gets. ;-)
Authorized Builder
my BFM gear:
Bas Gooiker
Re: dutch Titan 39
#25 Post by Bas Gooiker »
I just recieved my 6kg tub of Warnex. After seeing how much paint i used to base primer the cab i guess its a bit to much... So i guess i have to make more cabs as it would be a shame to waste good Warnex. :wink:
Question: How do i apply the Warnex? I got a few different rollers varying from standard foam rollers to "structure" ones. Wich one would be the best to use?
Patrick Mos
Re: dutch Titan 39
#26 Post by Patrick Mos »
You can use the standard foam for a nice surface, with a little "spikle" in it. if you use the structure roller you get more....well, structure. ;-). The structure roller give it a more "pro" look.
If you've got to much warnex, save it for the next t39 or dr200...., or sell it to me for a nice price. lol.
Can't wait to see the pictures!
Authorized Builder
my BFM gear:
Re: dutch Titan 39
#27 Post by Grant Bunter »
Bas,
How wide is your cab?
Not trying to be horrible but the access panel opening looks like it is way to large. And you have no panel 7's...
Bas Gooiker
Re: dutch Titan 39
#28 Post by Bas Gooiker »
The cab is 52cm wide. 49,5 inner panel size.
I am aware of that Grant, but i made a single large acces panel with bracing on the back side. I have the 2 other panels cut as per the plans but i did'nt like the look as much as with 1 full panel. If it turns out to be leaking and/or vibrating i will just do it as in the plans. If i fail i will report this and surrender myself to your "I told you so" 's! :cop:
I'll make a picture of my not following the plans sin later, as currently the front is wet with paint so flipping it over for a photo is not possible.
Re: dutch Titan 39
#29 Post by Grant Bunter »
Arrrr then it's all good! :wink:
You made a conscious decision to DIY lol.
I'm a bit wary of mistakes lately... some of them is from not understanding the plans, some plain ignorance, you get the drift.
That panel cops a pounding. And I admit my access panel is larger than it should be :slap:
Re: dutch Titan 39
#30 Post by AntonZ »
Thanks Bas and Patrick. The Alpha's are about 50 euro each indeed. That adds up for 8 drivers. Going to look into the Fane alternative, thanks. I have also seen some 4" drivers for €4 each that would take about 20W. A 9 driver cab would be narrow and neat, but there are not many specs available and I'm not sure how it would hold up for band PA tops use. On the other hand, for that price I could afford to build a pair and see how it works out.
