TLAH PRO Build
Re: TLAH PRO Build
I front loaded mine and "sealed" the baffle with gasket material and screws. Works great. My baffle is removable. Are you thinking of permanently attaching the baffle (as in glue)? Could make wiring a blown driver a nightmare...
Re: TLAH PRO Build
Dunno if its been said here lately.... but Alcohol and power tools can be a deadly mix. Please be cautious. Dont want to read another story here about lost fingers.
2-Jack 10
2-Wedgehorn 8
1-Auto Tuba
2-Wedgehorn 8
1-Auto Tuba
Re: TLAH PRO Build
Yeah, I have considered the wiring issue, I just figured if I leave me a lil xtra slack in the wires I should be able to pull them. I think Ill just front load and use screws and gaskets for the baffle. What did you use for a grill? Im kinda unsure of how Im gonna address the grill issue, never made one of those!groig wrote:I front loaded mine and "sealed" the baffle with gasket material and screws. Works great. My baffle is removable. Are you thinking of permanently attaching the baffle (as in glue)? Could make wiring a blown driver a nightmare...
Thanks for you concern Rickisan, and thats good advise of which I heed. Actually, that six pack of beers has been down there for months, I think its expired!Rickisan wrote:Dunno if its been said here lately.... but Alcohol and power tools can be a deadly mix. Please be cautious. Dont want to read another story here about lost fingers.
Like us on Facebook:
http://www.facebook.com/pages/Nine-Year ... 9339908177
Check out our vids Youtube:
http://www.youtube.com/user/nineyearsgo ... rid&view=0
Re: TLAH PRO Build
Make a frame and cover it with something from here http://www.parts-express.com/wizards/se ... h&x=20&y=9
You could use neo magnets set in the baffle and in the grille frame. Or, http://www.parts-express.com/wizards/se ... et&x=0&y=0
Re: TLAH PRO Build
thanks for the info Tom, thats kinda the way I was leaning. Infact I had those rubber frame mounts saved in my PE wish list! lol I havent decided on gray or black for the covers yet. Might play it safe and go black...or live on the edge and go grey!
Tom Smit wrote:Make a frame and cover it with something from here http://www.parts-express.com/wizards/se ... h&x=20&y=9
gzc_stageTech
Re: TLAH PRO Build
Hey chenry,
Did you make any progress today?
I finally got started cutting wood today too for my TLAHs. It was nice weather in Kansas today, but the clouds are rolling in this evening. It's supposed to rain here all day tomorrow. I'll shoot some photos tomorrow after church and start a new build thread (I don't want to hijack yours).
So, did you go get some 1/4" material to make a router template for the restof you driver holes? A little time spent tooling will save a lot of time repairing. Plus, the router leaves the holes so pretty.
Show us your progress. I'm eagerly following your build.
Chris
Chris
Re: TLAH PRO Build
Im just north of you about three hours in Des Moines, IA, it was perfect weather today. Unfortunatly I work 12hr shifts on the weekends so I havent gotten much done in the last couple days. I did get my 1/4 wood today, primer and gasket take from Menards. I plan to get things setup for routing tommorrow. Ill be sure and post any progress. If you want to post your progress on this thread feel free! I dont mind.
gzc_stageTech wrote:Hey chenry,
Chris
gzc_stageTech
Re: TLAH PRO Build
chenry78 wrote: I did get my 1/4 wood today, primer and gasket take from Menards.
+1 for Menards. They have 1/4" Baltic Birch in 4 x 8's. I snagged one myself. I wish they stocked 1/2" tho.
The TLAH seems straight forward so far. Now to get some gluing done.
Chris
Re: TLAH PRO Build
Got some stuff done today. Finished routing the holes and starting working on the piezos. Hit me up with any feedback folks, thanks!
- Attachments
- quick sled/jig for cutting piezo melding
- 1331681325574.jpg (14.49 KiB) Viewed 2534 times
- piezo porn
- 1331681316829.jpg (15.24 KiB) Viewed 2534 times
- 1331677283575.jpg (14.85 KiB) Viewed 2534 times
- 1331675963781.jpg (17.12 KiB) Viewed 2534 times
- A lot smoother circles when you use circle jig
- 1331675946839.jpg (14.78 KiB) Viewed 2534 times
Re: TLAH PRO Build
Heres one of the piezo lineups. Got some abs glue today from ace, man they done give that stuff away! Anyway I would have started gluing tonight except I didnt have any wax paper
- Attachments
- oatkry.jpg (16.7 KiB) Viewed 2532 times
- 1331681756564.jpg (17.37 KiB) Viewed 2532 times
- 1331681744623.jpg (17.28 KiB) Viewed 2532 times
- 1331681390742.jpg (16.91 KiB) Viewed 2532 times
gzc_stageTech
Re: TLAH PRO Build
Looking great chenry. The driver holes seem to take forever, but the router does make it much more repeatable. And the holes look much better.
Your pizza arrays look sweet. Are you going to cut the baffle with you circular saw? Or, are you going to route the slot? It looks like the outside edge of the pizzas will get very close to the edge of the baffle. Just be careful when you cut it out.
Keep on. I'm moving along too (see my build thread).
Chris
Chris
Re: TLAH PRO Build
Ok, got the slots for the piezo arrays all cut and one of the piezo sets melded...Im one piezo short however b/c i cut my first piezo too short...needless to say i have 10 coming for backup..i cant believe i didnt order extras additionally!
Gonna sand and prime today!
One question I should start thinking about here is voltage..what should my limiters be set out? how do I compute appropriate voltage for each tower?
thanks!
thanks!
- cheapbasslovin
Re: TLAH PRO Build
I asked the same thing about my Jack and was told the equivalent of, "turn it down when it sounds crappy."chenry78 wrote:
One question I should start thinking about here is voltage..what should my limiters be set out? how do I compute appropriate voltage for each tower?![]()
thanks!
The big reason for limiting the subs is they don't sound crappy as a warning of things to come, they just die. Then you're sad.
Mrrmensneturguneffferremantun
gzc_stageTech
Re: TLAH PRO Build
chenry,
looking at your TLAH:
8 drivers (12-ohms each)
40W RMS
2-series x 4-parallel connection
The equivalent resistance load is 6 ohms, and with the rated power capacity of 320W:
voltage limit is 43.8V
current draw is 7.3A
Note, this excludes power consumed in the piezos and your filter circuit. So, please consider that.
Chris
40W RMS
Chris
Re: TLAH PRO Build
Thanks for the info Chris, much appreciated!
Heres some of todays progress..forgot to snap a shot of the piezos but they look great!! I cant believe how well they turned out actually.
I tried to get some good shots of my roundover'in job but I guess I'm meant for drumming, not snapping pictures!
- Attachments
- box19.jpg (18.88 KiB) Viewed 2435 times
- box20.jpg (10.8 KiB) Viewed 2435 times
- box21.jpg (17.35 KiB) Viewed 2435 times
- box22.jpg (18.7 KiB) Viewed 2435 times
- box23.jpg (13.49 KiB) Viewed 2435 times
