I prefer Pilsner.digi128pci wrote:Is it ok to use a lager dowel ?
18mm is OK. 15mm is better,
Bill Fitzmaurice wrote:I prefer Pilsner.digi128pci wrote:Is it ok to use a lager dowel ?
Guess im going to look for 5/8 pvc pipeBill Fitzmaurice wrote:I prefer Pilsner.digi128pci wrote:Is it ok to use a lager dowel ?
Bill, you do realise you just quoted something in Metric!Bill Fitzmaurice wrote:18mm is OK. 15mm is better,
I said I don't care for it. Never said I couldn't use it.Chris_Allen wrote:Bill, you do realise you just quoted something in Metric!Bill Fitzmaurice wrote:18mm is OK. 15mm is better,
Only above 40kHz.On a related question, does it make any difference if the finish is smooth or rough?
Do yourself a favor and build T39s. They use the same drivers as the T30 but get louder above 35Hz.digi128pci wrote:Soon i will start the build of the two T30 subs. But i am wondering if i should go for the 24" or 27" T30?
The drivers i will use are the Delta 12LFA, i had theme laying around so why not use theme.
Probably depends on what you are using them for. If you are good getting down to 40-45hz and don't need to go lower - then by all means, build the T39s. Much easier to move at 19 inches deep and louder. Build 'em with the 3012LF and you'll be blown away. Yes, you can v-plate 'em. Make as wide as you can handle.digi128pci wrote:Hello,
You made me rethink the subbs i planning to build. But i already bought the plans for the T30.
Maybe the T39 is easier to move around and to transport. Can you V couple theme too?
Is the T39 that much better than the T30?
.they are on the approved list.......use 'em.digi128pci wrote:You are right! ill go for the T39.
But i have the DELTA 12LFA drivers laying around so is it oké to use theme?
But will only go half as loud.Bruce Weldy wrote:they are on the approved list.......use 'em.digi128pci wrote:You are right! ill go for the T39.
