Once caulked to the baffle the tweeters add structural integrity, and they have to be caulked to be airtight anyway. My test box took 100w with no ill effect. Just in case I've added a stiffener between the baffle and main brace.Radian wrote:Red is the area of greatest deflection along the Z axis using a pressure applied across the entire face of the baffle.
SLA Pro
Re: SLA Pro
Re: SLA Pro
Got the Alpha 6s today. Wife says "oh they're so cute". Cute and stout! They feel like they weigh as much as a BP102.
The four screws are going to be enough for these bad boys to stay airtight in the Arauco, being moved around as a pro rig?
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
Re: SLA Pro
The load is 1 pound per screw, so it should be fine, especially if you caulk them per the plans.bzb wrote:Got the Alpha 6s today. Wife says "oh they're so cute". Cute and stout! They feel like they weigh as much as a BP102.
Re: SLA Pro
Ah, thought the piezos were only thing caulked, as the Alphas have the soft gasket. Sounds good, thanks.Bill Fitzmaurice wrote:The load is 1 pound per screw, so it should be fine, especially if you caulk them per the plans.bzb wrote:Got the Alpha 6s today. Wife says "oh they're so cute". Cute and stout! They feel like they weigh as much as a BP102.
Bobby Shively
Re: SLA Pro
I specified the caulking for structural strength, what with the 1/2" baffle and all.bzb wrote: Ah, thought the piezos were only thing caulked, as the Alphas have the soft gasket. Sounds good, thanks.
Re: SLA Pro
Understood. Found some Recex-like screws that I've been using on some other projects, so I'll likely use those with the silicone caulk.Bill Fitzmaurice wrote:I specified the caulking for structural strength, what with the 1/2" baffle and all.bzb wrote: Ah, thought the piezos were only thing caulked, as the Alphas have the soft gasket. Sounds good, thanks.
One last question (I hope). Suitable for dampening material? Was 75% off at Target. Says memory-foam on it, and I know we've had threads about memory foam before, but wasn't sure what your take on it was. I'm planning on installing it before I attach the baffle to make it a little easier to staple.
Bobby Shively
- Harley
Re: SLA Pro
You have to be careful to programme the foam so it does not have "Mistake Memory" - otherwise all your bum notes will be repeatedbzb wrote:. Says memory-foam on it, and I know we've had threads about memory foam before,
Re: SLA Pro
No worries, I'm not a bassist.Harley wrote:You have to be careful to programme the foam so it does not have "Mistake Memory" - otherwise all your bum notes will be repeatedbzb wrote:. Says memory-foam on it, and I know we've had threads about memory foam before,![]()
Bobby Shively
Re: SLA Pro
Good quality memory foam has much higher density and weight than standard foam, and that's not good for damping, it can result in an over-damped cab.bzb wrote:
Re: SLA Pro
Ah, well - it was $5 for that whole roll, so I figured it was worth a shot. I still have some old foam left over that should be enough for both of these cabs.Bill Fitzmaurice wrote:Good quality memory foam has much higher density and weight than standard foam, and that's not good for damping, it can result in an over-damped cab.bzb wrote:
Waiting for stuff to come in the mail is killing me
Bobby Shively
Re: SLA Pro
Re: SLA Pro
It's probably twice as heavy, for the same size piece. Same thickness.Bill Fitzmaurice wrote:Compare it to the standard foam for density.bzb wrote:
Bobby Shively
Re: SLA Pro
Re: SLA Pro
What are the effects of overdamping?
Re: SLA Pro
Dead/dull sounding speakers.E.M. wrote:What are the effects of overdamping?
