Soldering tips/alternatives?
I am in the process of wiring up 2 tlah's, and 3 sla's.
So far 1 box has taken 3 hours.
I really suck at soldering, and this is absolutley the crappiest part of my build.
It is extremely difficult to get the wire in the goldwood tweeters.
Any tips? Can I use those push on things? Seems like the goldwoods are designed for this.
What do I need to buy if the crimp on connectors are ok?
Re: Soldering tips/alternatives?
What are you soldering with? If it's a gun, chunk it. If it's a cheap pencil iron, chunk it. If you don't know about tinning the tip, using a wet sponge to clean with, etc., look up some soldering instruction on google - it will be well worth your time. Soldering is not hard with the right gear and education. Then with a little practice, you'll be a pro.
Hang in there...
Hang in there...
Tinning! Thanks for the reminder. Brings me back to shops class years ago.
Tinning has made it MUCH easier. Ditto for the clean tip, but I was already doing that.
I am using a pencil type iron. What do you recommend? And why?
Nothing wrong with a pencil if its a good one. So many of the cheap ones just don't get hot enough.
If you are going to be doing a lot of soldering or you just like to have decent tools, get a Weller soldering station (or something as good). You can get a variable heat station for around $50 bucks......it's worth every penny.
UROK
Is this sort of thing any good?
It works great stripping the paint on my house. Soldering? Not so much.UROK wrote:Is this sort of thing any good?
Yep, that's the one I have. Just got it in the middle of my build when my old iron bit the dust. I first tried a cheaper station.....got it home and it wouldn't melt solder. Took it back, spent a little more and got this one. I love it. Put it on 5 for speaker cable - turn it down to about 3 for soldering mic cables. Best one I've ever had.bean438 wrote:Bruce, is this what you are talking about?
http://www.amazon.com/Weller-WLC100-Sol ... B000AS28UC
i have this exact soldering station and it works awesome; i have solder alot of things with it. make sure you tin your the tip first.
http://www.parts-express.com/pe/showdet ... er=374-100
I saw that one in the Parts Express flyer a while back and was wondering if it was any good. Thanks for the recommendation.BoostFab wrote:i have this exact soldering station and it works awesome; i have solder alot of things with it. make sure you tin your the tip first.
2x HL10c Table Tubas
9/12 TLAHs
9/12 TLAHs
go for it, you wont be disappointed.bossman wrote:I saw that one in the Parts Express flyer a while back and was wondering if it was any good. Thanks for the recommendation.
i used it to solder several of these controller boards and other diy projects. tin the tip properly and it'll last
I have that same soldering station and it works great. That is by far the biggest PITA about the TLAH or SLA speakers. The soldering is very labor intensive and takes a lot of time. The end result will be worth it though.
