For you experienced builders - how long before Duratex stops offgassing?
My cab was sprayed on Thurs. I'm still smelling fumes - pretty mild, but still present.
How long before the duratex stops offgassing and I'm fume-free? My wife is pretty chemical-sensitive, so it's pretty important.
Thanks!
Duratex offgassing - how long?
If God had meant for us to use flatwound strings he'd have stopped our hearing at 500 Hz.
Re: Duratex offgassing - how long?
Leave it outdoors in the summer sun and it's fully cooked in two days. In winter I can't say.
Put a fan on it and it will cure much quicker if the sun is not available. Phil
DR 250's #2
T39's 14 in with 102 #2
It cures faster with heat and without humidity.pwfirst wrote:Put a fan on it and it will cure much quicker if the sun is not available. Phil
4 DR250s
4 Tuba36s @ 30" wide
2 ATs
4 DR250s
2 ATs
- Harley
...as does other acrylics. Makes perfect sense.jcmbowman wrote:It cures faster with heat and without humidity.
