Duratex on Melamine?
David Carter
#1 Post by David Carter »
Before I get into cleaning up the garage after several months of cab building, I decided it was time to finally build a V-plate for my T39's. The only piece of wood I have that's big enough is a piece of 3/4" white melamine-coated particle board. It's the stuff they sell for making shelves, etc.
I've already cut the V-plate to size, but now my question is whether or not I should put a coat of Duratex on it. I'd like it to be black to match the cabs and to give a protective coating to the edges that don't have the melamine on them, but I don't know whether the Duratex will stick to the melamine or not. I tried going over it with my orbital sander and a 60-grit disc to roughen up the surface, but it didn't do anything to the melamine coating.
What do you guys think?
Dave
- 2 x Titan 39 (BP102 - 14"W)
WB
Re: Duratex on Melamine?
#2 Post by WB »
I would primer first.
David Carter
#3 Post by David Carter »
Black latex? I've got plenty left from the gallon I used on the cabs.
Dave
#4 Post by Bill Fitzmaurice »
Melamine isn't quite teflon, but it's close, not much will stick to it.
DaveK
#5 Post by DaveK »
Melamine usually has particle board as a backer. That makes it both heavy and not very strong. Plus, you'll cut your fingers on the edges sooner or later. Get a sheet of 9/8" flooring plywood and cut the plate from that. It's lightweight and strong enough to stand on. Round over the edges, fill the big knots, and then finish it with Duratex.
Israel
#6 Post by Israel »
I use a belt sander over formica covered panels, you need to peel all corners about 1 inch from the border and the rest try to get out 40 to 50% of the melamine over all the panel if you wanna be sure that the duratex sticks you can also throw a very small cap of contact cemment or perhaps prime and sand
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
#7 Post by LelandCrooks »
http://www.zinsser.com/product_detail.asp?ProductID=11
You can prime glazed ceramic tile with this stuff. Sand it all with 100g so there's some tooth, prime with this.
ben.in.salzburg
#8 Post by ben.in.salzburg »
How will you ensure it is strong enough?
I had to use 1 inch ply with reinforcing and it still flexes when people stand on it!
David Carter
#9 Post by David Carter »
ben.in.salzburg wrote:How will you ensure it is strong enough?
I don't do any events where people are likely to stand on it. If I ever think that will be an issue, I'll do a second v-plate and double them up.
Dave
ben.in.salzburg
#10 Post by ben.in.salzburg »
I'd prefer it that way too. Eliminating risk is better than reducing it.
Your audiences must be much more civilized than mine... or your security better! :)
David Carter
#11 Post by David Carter »
LelandCrooks wrote:http://www.zinsser.com/product_detail.asp?ProductID=11
Bought a quart of this stuff yesterday at Lowe's. As soon as I get a chance, I'll slap it on, and see how well it does. :fingers:
It's advertised as being tintable, so I asked the guy at the paint counter to tint it black for me, but after talking to him about what I was going to be using it for, I decided to leave it white because he said that the more tinting he put in it, the less it would stick to the melamine. If that's true, I'm glad he asked what I was using it for before he added the tint.
Dave
#12 Post by LelandCrooks »
Well ventilated area. It flashes off really fast, has some very potent stuff in it that makes it adhere to just about anything.
djwoo
#13 Post by djwoo »
try this: http://www.rustoleumibg.com/product.asp ... =2&pid=132
in USA would be easy to find,epoxy resin in aerosol, very durable and sticks to anything.
¿TEQUILA?...
