what setting for limiters
Scott Brochu
#1 Post by Scott Brochu »
On my DCX 2496 it has limiter capibility but I do not know how to set it and how high to put it. I have blown 2 speakers and do not plan on blowing another.
I see on the DCX screen that there is box with a line through it kitty corner but do not know how to set it...Lets just leave it at I do not know. :oops:
Someone out there must be using the same drive rack and give me some advice. I mean it isn't suppose to change every venue is it?
Thanks
Drumming is a way of life.
ME LIKE TO HIT THINGS!
David Carter
Re: what setting for limiters
#2 Post by David Carter »
I also have the DCX. Here's the discussion that ensued when I posted about limiter settings recently: http://billfitzmaurice.net/phpBB3/viewt ... f=6&t=8755
Dave
- 2 x Titan 39 (BP102 - 14"W)
Scott Brochu
#3 Post by Scott Brochu »
Thanks David, I did follow that thread but got confused.
But if that is the way than I will print off and try. Should it be any different for Behringer tops compared to 200's?
let me try this and I will get back to this thread. We are not going to have full equipment out for a few weeks so it will be a while.
Thanks David. :wink:
Sydney
#4 Post by Sydney »
This has a limiter calc that might help...
http://www.dni-inc.com/things-here/misc ... _v1.12.xls
T_Gowan
#5 Post by T_Gowan »
Sorry to side line, Dave , did anyone ever answer your question about release time for the limiter settings? I noted some strange behaviour when setting up the upper band limiter, wondered if it had any thing to do with release time at higher freq.
Tom
IN PROGRESS Jack 10 Lite x2, hopefully 4
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
David Carter
#6 Post by David Carter »
T_Gowan wrote:Sorry to side line, Dave , did anyone ever answer your question about release time for the limiter settings? I noted some strange behaviour when setting up the upper band limiter, wondered if it had any thing to do with release time at higher freq.
Nope. I don't recall ever getting an answer on that.
Dave
Scott Brochu
#7 Post by Scott Brochu »
Calling all DCX 2496 owners
I did not want to start another thread on this subject, it does have stuff about a limiters.
OK
fine tuning the DCX........... Well lets just say figuring out. :lol:
I need to know if this stuff is right;
On the screen for the subs for limiters it reads
Thresh: -0.0. dB
Rel: (I got it at) 503
^^^right, please correct
Polarity phase ????Normal? <<<for subs/mains/monitors.
Input source screen, should it read 0.0 dB's for gain and what is the correct type for monitors? is it Mid or Mid highs?
X over points screen reads;
type; L-R48 type; L-R48
Freq; 135Hz Freq; 16.9Khz
^^^monitors/subs/ mains what should it read for each?
Dynamic eq;
Thresh; -0.1dB
Ratio; -2.0:1
Attack; 71m5
Release; 501m5
^^^^for subs/mains/ monitors what should this read?
I know I am asking a lot out of some but just think of it as a lot of questions I would of asked in about....a year all rolled up in one night. On this subject. :lol:
I thank anyone who takes the time and answers me and my stupidity. I think this is why my lead singer wanted to buy a destroyer. Cause things are not set right.
If I can get through this with the right settings I think I am on my way a lot better than I was a yr ago.
