1 3/16" 18 gauge brads acceptable as substitute for 1.25"?
myn
#1 Post by myn »
Are 1 3/16" brads an acceptable substitution for the 1 1/4" length specified in the TT plans?
I couldn't find any 1.25" long ones at my local harbor freight.
Re: 1 3/16" 18 gauge brads acceptable as substitute for 1.25"?
#2 Post by LelandCrooks »
yes.
SoundInMotionDJ
#3 Post by SoundInMotionDJ »
+2
You'll be fine.
10 T39S + 10 DR200 + 1 T48
myn
#4 Post by myn »
Thanks for the confirmation :).
I went and tested my $14.99 nail gun (harbor freight coupon). Seems to work really good (so far). I drove 100 1 3/16" 18 ga brads into 1.5" MDF. This should hopefully speed things up for me, instead of using screws.
myn
#5 Post by myn »
I also didn't see any mention in the plans about how conservative you should be with the PL adhesive. How wide of a bead should be applied and should excess squirting out the sides be expected or ?
The reason I ask is the plans mentioned using a guideboard in alot of cases which is great except won't the excess PL adhesive leak and stick to the adjoining guideboard?
SoundInMotionDJ
#6 Post by SoundInMotionDJ »
myn wrote:I also didn't see any mention in the plans about how conservative you should be with the PL adhesive. How wide of a bead should be applied and should excess squirting out the sides be expected or ?
I use about a 3/16" bead on all the seams. You want even squeeze out along every joint. The guide board I use for supporting panels during assembly has a 1/2" chamfer along all the two "bottom" edges. That keeps it out of the PL.
--Stan Graves
myn
#7 Post by myn »
--Stan Graves
Ingenious!
David Carter
#8 Post by David Carter »
A not-so-elegant solution is just to use wax paper around the guide board. This prevents the board from sticking to the joint as well. You may have to scrape off a bit of wax paper after the PL dries, but that's no big deal.
Dave
- 2 x Titan 39 (BP102 - 14"W)
Harley
#9 Post by Harley »
David Carter wrote:A not-so-elegant solution is just to use wax paper around the guide board. This prevents the board from sticking to the joint as well. You may have to scrape off a bit of wax paper after the PL dries, but that's no big deal.
I wrap mine in Glad Wap ( food wrap ) but I think the chamfer is a better idea really. My guide board only stays there for a minute or so before I move onto the next operation.
