I had almost forgotten about this tip. An electric knife cuts foam smoothly and quickly. Much easier than using a utility knife.
You can even cut without needing a backing surface, just holding the foam sheet in your hand. When doing so, you have to exercise caution.
Use electric knife to cut your mattress topper
Re: Use electric knife to cut your mattress topper
Yes, an electric knife makes for perfect cuts.
I like to use the edge of a bench as a straight edge, but free hand works also.
I use scissors.
- Scott Brochu
That must cut that 2" foam that goes in Flight Cases?
Gathering info.
Gathering info.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
