Use electric knife to cut your mattress topper
Rick Auricchio
#1 Post by Rick Auricchio »
I had almost forgotten about this tip. An electric knife cuts foam smoothly and quickly. Much easier than using a utility knife.
You can even cut without needing a backing surface, just holding the foam sheet in your hand. When doing so, you have to exercise caution.
WB
Re: Use electric knife to cut your mattress topper
#2 Post by WB »
#3 Post by Bill Fitzmaurice »
I use scissors.
Scott Brochu
#4 Post by Scott Brochu »
That must cut that 2" foam that goes in Flight Cases?
Gathering info. :mrgreen:
Drumming is a way of life.
ME LIKE TO HIT THINGS!
