I opted to not put buttcheeks as the subject...Has anyone tried to make their own out of fiberglass? I am a composite hobbyist and could easily make some. I have had no luck finding 1/4" or 1/8" (locally) here in MI.
One UK speakerbuilder I saw made whole horns out of fibreglass
He used double layer thick ladies tights stretched around a frame, which he then fibreglassed onto and then added layers at will. It worked very well apparently. I am sure it could be reproduced quite easily.
I'm very curious...
Worked for a short while in a composite fabrication plant - looong time ago.
Since then dabbled/experimented with different things.
Got links?
