Easiest way to cut the plastic corners
What's the easiest way to cut those plastic chevron corners? How do you hold them down while cutting? I know, I'm such a nOOb!
- David Carter
You can also use a sharp utility knife and cut with a pushing motion so that the plastic is being pushed against the wood as it's being cut. This way the edge of the wood can act as a guide.
Dave
- 2 x Titan 39 (BP102 - 14"W)
wallywally
gdougherty
HOW IN THE HELL DID YOU GET MY PIC?????Nordskov wrote:Well I think the best way to cut corners is to lay down your tools, let the couch jump on to your back and having a six-pack and the remote in close proximity.
Sorry about the NAB. It won't happen again
How did you get hold of my secret recipie?Harley wrote:I sense some competition!!!Nordskov wrote:Well I think the best way to cut corners is to lay down your tools, let the couch jump on to your back and having a six-pack and the remote in close proximity.![]()
It has been in the family for decades - and we are getting better and better.
I guess my old lady has being talking loose - probably to some of her friends, yeah. How about that.
- Paul Norman
Re: Easiest way to cut the plastic corners
You don't, assuming you want to keep all of your fingers. As is the case with cutting any small parts use of a jig is the only safe method. The type of jig depends on the cutting tool. I cut mine on a sliding compound miter saw with abrasive blade.DJPhatman wrote:How do you hold them down while cutting?
I use aviation snips. You'll have to ruin a few to learn how far back to end your cut. It will crack right to the spot after you figure it out.
- Harley
I never cut mine down.....too friggin' dangerousDJPhatman wrote:What's the easiest way to cut those plastic chevron corners? How do you hold them down while cutting? I know, I'm such a nOOb!
