Easiest way to cut the plastic corners
#1 Post by DJPhatman »
What's the easiest way to cut those plastic chevron corners? How do you hold them down while cutting? I know, I'm such a nOOb! :roll:
Tim A
#2 Post by Tim A »
Are you talking about the 3/4" lip that needs to be cut back for the 1/2" ply? If so, I use a router and a jig. I think I'm the only one. Someone else once said they used metal snips with good success.
David Carter
#3 Post by David Carter »
You can also use a sharp utility knife and cut with a pushing motion so that the plastic is being pushed against the wood as it's being cut. This way the edge of the wood can act as a guide.
Dave
- 2 x Titan 39 (BP102 - 14"W)
wallywally
#4 Post by wallywally »
I score 'em and then crack 'em
gdougherty
#5 Post by gdougherty »
If you're talking about for larger corners like on the WH, I took a small handsaw and just held the corner down against a workbench while I sawed the corner to allow the larger spread.
Nordskov
#6 Post by Nordskov »
Well I think the best way to cut corners is to lay down your tools, let the couch jump on to your back and having a six-pack and the remote in close proximity.
:lol: :lol: :lol:
Sorry about the NAB. It won't happen again :oops:
Greenman
#7 Post by Greenman »
Nordskov wrote:Well I think the best way to cut corners is to lay down your tools, let the couch jump on to your back and having a six-pack and the remote in close proximity.
:lol: :lol: :lol:
Great pic.
Cheers
Brent K.
#8 Post by DJPhatman »
:lol: :lol: :lol:
HOW IN THE HELL DID YOU GET MY PIC?????
Nordskov
#9 Post by Nordskov »
DJPhatman wrote:HOW IN THE HELL DID YOU GET MY PIC?????
So you are in charge of the NAB?!
Shame on you.
Such a cute little innocent puppy and you serve that kind of hiddeous liquid.
I see no other alternative than to turn you in on inhumane treatment of animals. Outrageous!
:lol: :lol: :lol:
Harley
#10 Post by Harley »
Nordskov wrote:Well I think the best way to cut corners is to lay down your tools, let the couch jump on to your back and having a six-pack and the remote in close proximity. :lol: :lol: :lol:
I sense some competition!!! :lol: :lol:
Nordskov
#11 Post by Nordskov »
How did you get hold of my secret recipie?
It has been in the family for decades - and we are getting better and better.
I guess my old lady has being talking loose - probably to some of her friends, yeah. How about that.
Paul Norman
#12 Post by Paul Norman »
To cut down the corners I used a jig with a guide and end stop on the band saw. Worked slick but I did 100 of them.
Re: Easiest way to cut the plastic corners
DJPhatman wrote:How do you hold them down while cutting?
You don't, assuming you want to keep all of your fingers. As is the case with cutting any small parts use of a jig is the only safe method. The type of jig depends on the cutting tool. I cut mine on a sliding compound miter saw with abrasive blade.
#14 Post by LelandCrooks »
I use aviation snips. You'll have to ruin a few to learn how far back to end your cut. It will crack right to the spot after you figure it out.
Harley
#15 Post by Harley »
DJPhatman wrote:What's the easiest way to cut those plastic chevron corners? How do you hold them down while cutting? I know, I'm such a nOOb! :roll:
I never cut mine down.....too friggin' dangerous :shock:
