Remove screws, fill holes with bondo - needed for carpet?
kesslari
#1 Post by kesslari »
Hi,
Omni instructions mention filling the screw heads with bondo, and I've seen some references to removing the screws and filling the holes with bondo.
Is this just for a duratex/paint finish (makes sense there, for a quality even finish) or is it also necessary for a carpeted finish?
Build day tomorrow, if health and weather hold up...
Wish me luck!
JK
Mikey
#2 Post by Mikey »
Either countersink screws and leave them in, or use flathead screws and take them out. It's up to you. Either way, fill the holes.
#3 Post by Bill Fitzmaurice »
I pull screws near edges that might get hit by a router roundover bit. Otherwise leave them in, bondo them over.
