Tim Ard's OmniTop thoat horn fillers
Les Webb
#1 Post by Les Webb »
Because of time restraints I recently bought some thoat horn fillers from Tim to use in one of my builds. I also contracted him to build me the low pass networks custom built onto a jack plate with NL4 speakons for a pair of OT 2x12's.
Superb work all around, thanks Tim!
The throat fillers work great and are much better than the ones you can build from the plans. Not much more expensive than buying the little foam disks at the crafts store and carving. Just glue up and screw them on. I didn't even use washers on the drywall screws to hold them in. They work extremely well and I will be buying more in the future.
http://billfitzmaurice.com/phpBB2/viewt ... ebcce97a29
The craftsmanship on the jack plate/low pass filter was top notch. He even included a custom label with whatever I wanted written on it. Great work Tim and thanks for the help. Will try and post pics when I get the time.
Les
vlad335
#2 Post by vlad335 »
Agreed. Tim's a great guy. I ordered the fillers from him as well as I didn't want to even attempt to find the material for them locally. He shipped fast and even PMed me to ask if I got everything OK.
Didn't think of asking him about building jack plates... Hmmmm.
Mr. Ard, you have an email.
Tim A
#3 Post by Tim A »
:oops:
I'm blushing. Thank you both for the kind words.
The throat fillers really are a great option. They're tougher than styrofoam too. It's quite a bargain when you consider how much time you'd have involved in making them, not to mention driving somehwere to pick up the discs or sheet foam. My only problem right now is building up backstock on the 12", everytime I think I'm getting ahead someone orders more. Vlad damn near wiped me out!
Harley
#4 Post by Harley »
Tim Ard wrote::The throat fillers really are a great option. They're tougher than styrofoam too. !
What was the material you made them out of Tim.
I will be making some OTops soon and I might as well make a mold for the throat fillers at the same time - I can easy make up my own mold from sheetmetal.
Harley
Tim A
#5 Post by Tim A »
I used unobtainium.... :D
Seriously, any kind of liquid or canned foam will do.
Harley
#6 Post by Harley »
Tim Ard wrote:I used unobtainium.... :D
That's it - you're definitely on the visit list.
It would be fun having a few beers and trying to outdo each other on the stupidity list! :lol:
H
mty
#7 Post by mty »
H
:wink: smart very smart ..
bgavin
#8 Post by bgavin »
Harley wrote:It would be fun having a few beers and trying to outdo each other on the stupidity list!
Why not have a huge lot of beers, then you can both win?
:mrgreen:
Harley
#9 Post by Harley »
bgavin wrote:Why not have a huge lot of beers, then you can both win?
:mrgreen:
One has to start off with a few to reach many! :roll:
Tom O'Shea
#10 Post by Tom O'Shea »
I just got a bunch of OT12 throat fillers from Tim, and WOW!
Great job, Tim!
Tom O'Shea
brodave2
#11 Post by brodave2 »
I built my fillers out of styrofoam like the instructions said, and the instructions say to have at least 1/4" clearance between the filler and the speaker cone. Mine had more like an inch of clearance. I'm wondering if they do any good with that much clearance.
WB
#12 Post by WB »
brodave2 wrote:Mine had more like an inch of clearance. I'm wondering if they do any good with that much clearance.
I'd redo it and get that gap down. The idea is to remove the resonant chamber.
Tim A
#13 Post by Tim A »
Don't worry about the gap. The questions is: Did you make them to the correct specs? If you carved them out and they matched the size Bill put in the plans, then you're good to go.
Being DIY, Bill wants to make sure he covers his bases. I suspect the 1/4" is a bare minimum for cone clearance. Mine had a larger gap too, and I know they're right.
1/4" is the minimum, to insure the cone doesn't slap the filler. 3/8" to 1/2" is ideal. 1/2" to 3/4" is adequate. More than 3/4" and you're sacrificing some response.
