Hi,
Sorry if this has been asked before, but Iwas wondering if the new Faital 10RS430 would work in a wide Table Tuba? VAS is a bit high
FS: 32HZ
QTS: 0,28
VAS: 59,2L
https://faitalpro.com/en/products/LF_Lo ... =151040095
Table Tuba compability
Re: Table Tuba compability
It should work just fine. Vas is the least critical spec. But it's mighty pricey. I can see its value in a pro-sound T24 or T39, but for home theater it's overkill.
Good to know, thanks for the reply! It's quite expensive but here in europe we can get it cheaper than a Dayton Reference 10 inch subwoofer. And with front mounted gasket and superiour build quality it brings some peace of mind
Sure, since you have to import Dayton, but there must be other options at a sensible cost. For instance: https://lavocespeakers.com/product/ssf102-50l/
