Table Tuba compability
cbarth
#1 Post by cbarth »
Hi,
Sorry if this has been asked before, but Iwas wondering if the new Faital 10RS430 would work in a wide Table Tuba? VAS is a bit high
FS: 32HZ
QTS: 0,28
VAS: 59,2L
https://faitalpro.com/en/products/LF_Lo ... =151040095
Re: Table Tuba compability
#2 Post by Bill Fitzmaurice »
It should work just fine. Vas is the least critical spec. But it's mighty pricey. I can see its value in a pro-sound T24 or T39, but for home theater it's overkill.
cbarth
#3 Post by cbarth »
Good to know, thanks for the reply! It's quite expensive but here in europe we can get it cheaper than a Dayton Reference 10 inch subwoofer. And with front mounted gasket and superiour build quality it brings some peace of mind
#4 Post by Bill Fitzmaurice »
Sure, since you have to import Dayton, but there must be other options at a sensible cost. For instance: https://lavocespeakers.com/product/ssf102-50l/
